Question about Exercise & Fitness
I am getting power but the control board is not functioning in my ct100 model threadmill
    Top Expert:
  • 12,223 Answers
1) make the LUB in the deck belt treadmill use wd-40 read your owner manual.
2) test the input voltage terminal in your motor, if there ARE the motor is faulty.
3) test the output voltage control board, for input voltage terminal motor, see my personal TIPS for motor HELP, if there ARE NOT the board is faulty, see the diagrams attached.
God bless you
i am getting power but the control board is not fu - 1e54d3cc-1bff-45f5-ab62-50288cfc8401.jpgaa410f39-19eb-46b8-9623-4bfe5f7da740.gif
Posted on Nov 29, 2013
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
My Horizon T91 threadmill is moving slower than normal. I checked both belts and there is no slippage.I opened the cover for control board, a red LED on in the lower part of the board.How can I fix?
Can be the motor or the motor control board faulty. You have to check the motor brush if it's OK the you should go for a new Motor control board.
if you wish to get some more details about treadmill repair then check the following link.
Sep 26, 2016 | Horizon Exercise & Fitness
Threadmill does not always start
There would be some problem in wiring harness between motor control board and control panel. Try to remove form both side an reconnect it
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 10, 2016 | FreeMotion Xtr 90 Treadmill By Free Motion
What needs to be done after cangingm the battery on the circuit board ?
Possibly a loose connection, or dirt/foreign object on circuit board causing electric connections. clean board and connections, look for foreign object on electronics.
Jan 02, 2015 | Cars & Trucks
Proform xp threadmill immediately shuts down and flips the breaker
see the video and LUBE, this happen because the lack of maintenance schedule of lube.However if the problem persist after you did lube, see my persosnal TIPS for motor helps, and test it. a) main motor b) control board. c)old board deck too.God bless you8eec0b2b-b4e5-480b-a21f-11224625d652.jpg7ee45112-69c5-41ab-86a0-1794a9d3376d.gif
Mar 27, 2013 | Proform Exercise & Fitness
When I step on the threadmill deck, it stops working. Why?
1) You must LUBE inmediately the deck belt, this problem happen because the lack of maintenance. The machine has a device for protection for the electronic system, producing a shut down for to keep safe the electronic.
2) You must LUBE the rollers bearings too very well
3) Test the voltage input for motor, if there are the motor NEED REPAIR.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block .God bless you
Sep 03, 2012 | Exercise & Fitness
`convert threadmill from kilometer to miles on a freespirit threadmill
Dear Sir:
Inspect the bottom of your treadmill console.
Use the pencil point. touch the hole(nano swithc) and ready. Of course you must disconnect the power before. After you reconnect it. And ready.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Bowflex Exercise & Fitness
I need a motor controler?
Hi mat? Let me know if you still have the motr board of your l570 threadmill. I have busted transistor on my board. Have you fixed yours? Thanks
Oct 27, 2010 | RTO Volume L570 Treadmill
Bh fitness columbia threadmill - E1 error on screen
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Aug 08, 2010 | Exercise & Fitness
Err 1 on fitness club threadmill
Jul 30, 2010 | Life Fitness 9100 Next Generation...
Exercise & Fitness Logo
73 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
