Question about Yamaha RX-SL100 Receiver
While watching tv we heard a pop and the receiver stopped working. Power button does nothing. We've opened it up but can't see anything that looks burnt or fried...
Heard a pop sound and the audio stopped while watching tv. No sound from the receiver/surround system. Power button does nothing.
It could be a relay that burnt out, they usually dont show any signs of damage, or the motherboard could be fried too with no signs of damage eather! Hope this helps!
Posted on Nov 29, 2013
Testimonial: "If it is, is it worth (i.e. not likely to cost a lot) taking it to a shop for repair or just get a new unit?"
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
  • 6 Answers
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
  • 52 Answers
SOURCE: Turning OFF Yamaha Receiver with Dish Network Remote.
When using codes from a multi unit remote from say... the cable company, you have to check all the various codes for that brand. Some will turn it on but not off some will work the volume but not the menus. try manually inputing all the codes for that brand. Its a tedious process but the auto setup is not going to allow you to test all the functions like you should before commiting to one code. your remote should have come with a brochure containing all the codes for your particular type of unit and brand. Good Luck!
Posted on Dec 17, 2009
SOURCE: Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Posted on Apr 03, 2010
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
I was watching my Hitachi 42hdm12 and heard a pop and now the picture won't show up or sound or anything?
A pop is usually a power surge and you blew a board. If you take the tv apart, if this is it, it will be evident by the burn marks. You could have burned out the internal power supply as well.
Oct 04, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Vizio Quit Working
Hello, This is a problem with the power supply board, the pop you heard was a capacitor (it exploded). If you do not have a background in electronics, please have a qualified TV Technician repair the TV set. There are no user repairable parts in the unit. In any event the power supply board needs to be repaired. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | Vizio VO47L 47 in. LCD TV
I heard a pop from my tv and then the tv didn't work
Anything is repairable as long as the screen isn't damaged.
The sound you heard is most likely was a capacitor that just went dead.
Solder in a new capacitor should fix the problem. It would most likely be on the power supply board somewhere.
You'll need the Service Manual for parts list, diagrams, and schematics. Here's one place for that:
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=pdp-503cmx+service+manual&forward=plist
Any other questions just ask.
May 10, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Tv will not turn on - watch and heard a pop a shut off
it probly had a power surg and blw a fuse ther r like five one in each corner and one ine the midel had same prolblum the glass braks on the fuse thet probley was the pop u heard
Nov 10, 2008 | Televison & Video
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
Tv popped and stopped
The over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. It's best to have a Certified TV repairman look at it. Generally when this happens, the TV keeps getting worse and repairs can get expensive. If the repairs are over $300, then I would look into buying a new set.
Jul 12, 2007 | Orion STV2763 27" TV
Yamaha RX-SL100 Receiver Logo
79 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
