Question about Sony Video Game Consoles & Games
Is there any alternative to using hdmi input to the tv
    Master:
  • Sony Master
  • 665 Answers
Yes, there are several ways to connect to the tv. HDMI is the (NEWER) way to connect the console. The reason being, is because HDMI carries both video and audio. The standard way to connect is by using the provided (RCA) cords that came with the system. They connect by splitting the video(yellow) and audio(white=left red=right) Almost all tv's out now have either HDMI or the audio/video inputs, and are typically cable ready.(little threaded plug in the back that your cable box hooks into) You can purchase a cable ready adapter from game stop or even use the one from an existing PS2 or PS1. They all use the same adapter from the system. The only difference is, if you don't connect with HDMI then you are NOT going to have high def available. It will be in standard def all the time. The final way to connect is a bit difficult. It requires a bit of knowledge in what your doing. HDMI to a HDMI adapter to DVI-I or DVI-D monitor. Some tv's come equiped with a DVI-D input so it can double as a monitor for a computer. This way WILL give you HIGH DEF and arguably the best picture you will ever get because you can set the frame rate (frpm) your self. Hope this info is useful. Good luck. ^^
Posted on Dec 06, 2013
  • Jane OBrien
    Jane OBrien Dec 14, 2013
    This is to attach a new xbox one to a tv where the hdmi is not responding.
There is no signal on my emerson tv, how do i get one
1. You are not on the right input for the signaling device: Verify which input number (or type ie HDMI/component/video/Cable) your device is connecting to and tune to that input.
2. The signaling device is not powered on. Verify it is on and the cable is properly seated into device and TV.
3. The cable is bad. Try a different cable or use alternate type of connection.
4. The specific input port on the TV is bad. Move the connecting cable to a different port (ie from HDMI 1 to HDMI 2) and tune the TV to that input.
If you are using an Over the Air signal (OTA) with rabbit ears or and antenna use the TV menu to run an auto tuning scan of your local stations.
If you are using a tuning box (cable/satellite) over a coaxial connection check connections and tune the TV to CH 3 or CH 4 and check for picture. There may be a switch on the back of the box indicating CH 3 or CH 4.
Sep 18, 2017 | Emerson Televison & Video
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Aug 24, 2014 | Computers & Internet
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I have bought a HDMI cable and I cant seem to get my Prosonic to work with my pc. It works on other TV's The cable works fine with dvd player. Is there somewhere on the TV I shall activate first? I...
How many HDMI Inputs are available on the TV? Also, are you trying to project your computer to the TV or get TV on your PC?
I will assume the first scenario. The only thing I can suggest is that if there are multiple HDMI inputs then you will need to choose the correct one to change it to. If it does not give you that option on the TV input switcher menu then you can try to plug and unplug (while everything is on and attempting to project) the HDMI cable into different inputs on the TV until you find the right one.
Alternatively you can use a VGA/DVI cable depending what is on the back of the TV and that will definately work, but won't be HD.
Hope this helps.
May 13, 2011 | Prosonic Televison & Video
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
We have a Polaroid 4241-TLXB television. This evening we turned on the TV and the Video6 (HDMI1) is not accepting sound. The picture is fine when that input is selected. We had our STB attached to HDMI1...
I am having a somewhat similar experience. The HDMI 2 is a little flaky on these TVs, try turning the input device that is attached to HDMI 1 OFF then reboot the TV. For some reason, if there is a signal going to both HDMI inputs at the same time there are major problems. I also found that if I input L/R audio into the HDMI 2 analog jacks, that sound also goes to HDMI 1(if no digital sound signal is going there).
Feb 16, 2011 | Televison & Video
When hooking up HDMI why can I not get sound I hooked the HDMI from the cable box to the reciver and from the reciver to the TV I assinged the Hdmi and I get picture on the Tv I also can get sound out of...
I have researched on your issue and found that the Receiver is not capable of processing audio from HDMI input. It will bypass the signals from its HDMI input to HDMI output..
The Receiver has 3 HDMI input and one output. Hence you can use this as a HDMI switch to connect three HDMI devices to single HDMI port on the TV.
In order to get the sound from speakers connected to the Receiver, it is required to make alternate digital or analog audio connection.
You can confirm the information from the manual of the Home Theater System. Please refer page # 36 of the Manual to get the information. I have provided a link where you can download the Manual for the HT System:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/580/580HT5100B.PDF
Jan 15, 2011 | Onkyo HT-S5100 Theater System
Screen goes yellow, fades, then NO SIGNAL
try using an alternate input source like a dvd or game console and see if you can duplicate the problem. then call vizio support and describe your problem. a lot of vizio parts have lifetime warranties on certain parts and a free service call to change out parts.
could have an issue with main board that has hdmi input. if you have 2 hdmi inputs on the TV, try the alternate input, too. vizio has had some issues with main boards. have worked on them for 3 years. hope this helps.
Apr 07, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
Video Game Consoles & Games Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
