Question about Exercise & Fitness
Do you have control board for the dyaco CT100 treadmill
2 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: treadmill model 909 made by
surely there is some problem in the belt.
One of the ways to extend the life of your treadmill is to keep it clean and dust-free. Dirt and dust build-up, especially between the belt and the deck of your treadmill can cause excessive belt-deck friction. This in turn, can damage your electronics and even your motor.
You can check for excessive belt-deck friction by setting your treadmill around 4 MPH and walking on it. Press the stop button (or pull the emergency stop switch). You should have to take a few steps before the belt stops - if it stops suddenly there is probably a high friction problem.
Excessive belt-deck friction can also cause motor to stall or sound labored so again, keep your belt and deck free from dust and dirct and look out if this is a problem
Posted on Jan 26, 2011
Manual for 1622738 Dyaco Freesprit treadmill
http://pincoffs.ca/files/Download/1622766en.pdf
Jan 31, 2015 | Cell Phones
I am getting power but the control board is not functioning in my ct100 model threadmill
1) make the LUB in the deck belt treadmill use wd-40 read your owner manual.
2) test the input voltage terminal in your motor, if there ARE the motor is faulty.
3) test the output voltage control board, for input voltage terminal motor, see my personal TIPS for motor HELP, if there ARE NOT the board is faulty, see the diagrams attached.
God bless you
Nov 29, 2013 | Exercise & Fitness
Dyaco treadmill model 909
Please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor and see the steps. God bless you
Oct 10, 2013 | Exercise & Fitness
Trimline treadmill repair 7600.1 no power
please see the video and fix it. LUBE the deck belt+rollers bearing front+back +test the drive belt motor, and replace it if necessary.
God bless you
Jul 04, 2013 | Exercise & Fitness
When i plug my treadmill in the digital display wont read or turn on
1)ADJUST THE SENSOR REED SWITCH BY 1/8" SEE THE DIAGRAM
2) IF YOUR SISTEM HAS BATTERIES EXCHANGE BY NEW ONES.
3)TIGHT THE FLEXIBLE CABLE FROM THE KEYPANEL VS DISPLAY BOARD AND THEN TIGHT THE CONNECTOR FROM THE DISPLAY BOARD VS LOWER BOARD OR MAIN MOTOR CONTROLLER BOARD.
4) WILL BE A GREAT IDEA IF YOU CAN MEASURE WITH YOUR VOLTEMETER +5VDC coming from the main motor controller board to display board.
Now if there are missing the fault: is main motor controller of course after you did the first step or the voltage is there the display board is faulty.
12_6_2011_1_18_12_am.gif12_6_2011_1_18_35_am.gifsee the block diagram how the main motor board control by 90percent of function of the any treadmill. Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Dec 06, 2011 | Weslo Cadence 55 Treadmill
I hav e Model # HRTL7183 The speed control buttons do not work so it will not run I am told the contol board is no longer available
the control board is still available for this i am sure of it. you may have to get a used one. look at ebay. this is an icon treadmill i am sure. probably has a mc-60 or somethin like that. i have a few spares. look on the treadmill and it should say on the control board what type of board it is. it is located in the motor area the computer board should say what model it is. go to treadmill doctor. com
Jan 27, 2011 | HEALTHRIDER R65 Treadmill
Everything works. but the treadmill motor won't start when I press the on button.
If you press start and the belt will not turn, but your incline is working, the time is counting and the speed #'s change. The problem would most likely be the lower control board. It could also be your motor. Have a professional test the motor with a DC voltage source. If it tests OK the problem is almost certainly the control board. Depending on the brand, some control boards have a fuse. Have the fuse checked and if it is bad replace it and try starting the treadmill again before you buy a new control board.
Nov 23, 2010 | Proform CrossTrainer Treadmill
Hi, where can i get a C2100E motor control board for my Nordick Track C2500 ?
Two places either iconservice.com under replacment parts or Treadmill Doctor.com under treadmill products
Jul 19, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
120 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
