Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Kenmore 11021302010 won't spin
Clothes still wet
Wont final spin
sorry have not come across that model its not within my expertise
Nov 14, 2011 | Washing Machines
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
After spin clothes are still wet kenmore 110-20702990
If your clothes are still wet after a spin cycle it can indicate that you may have either a drainage issue and the water is coming back into the machine after the spin, or your drain pump has broken some or all of its impellers that force the water out. i hope you found this useful.
Thanks.
Oct 10, 2009 | Kenmore Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
