Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Water dispenser stops water flow
Indoor water dispenser starts then suddenly stops
  • 21 Answers
Sounds like you are losing power to the water valve. The only way to be certain, would be to use a volt ohm meter and test. Push in and out, repeatedly with a glass you can usually tell, if the dispenser switch Clicks or not. If the Switch were "no Good" you won't here it or Feel it "Clicking". It's not likely, but if it were mine... I 'd want to get back there and look to make sure I don't have a "Crack" in the plastic Fill Tube and it's getting wet back there -Just to be safe.
Posted on Nov 29, 2013
Front Fill water dispenser suddenly stops
Not totally up with that Amana but just check you have not inadvertantly set it up to fill at a certain level, low, meduim, high etc.
Nov 29, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
Water dispenser sudden low flow/pressure. Bottom freezer KBFA25ERss. I have replaced valves, removed every segment of line and blown them clear from dispenser tip to supply line. Supply pressure and flow...
Sounds to me you have something wrong with the filter and retaining air there. That air must be purged to get the pressure you need from water supply. Double check that water filter I think your problem is there, Thanks Sea Breeze
Aug 17, 2012 | KitchenAid Architect KBFA25ERSS Stainless...
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
My water dispenser suddenly stopped working. it makes noise like it wants to dispense water but it doesn't. the ice maker also stopped working
You probably have no water flow to your water valve due to either a blocked water valve or water source is cut off. You can take off the valve (just two crews hold it on ,and disconnect water lines. Don't worry about getting lines mixed up as the are sized specifically) Clean the valves intakes and reinstall. Hope this helps
Jul 27, 2009 | Refrigerators
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water stopped running in the dispenser
i ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Mar 16, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
