Question about Sony Playstation 3 (PS3) Console
Change sony to hdmi capable - Sony Playstation 3 (PS3) Console
    Genius:
  • Sony Master
  • 1,148 Answers
Just connect hdmi,,to ps3 and tv,,power on both and go to hdmi on tv,,should detect it ,,ps3 should pop on screen,,,then when it does choose automatic ,,if it dont hold power to get a few beeps there u go
Posted on Nov 29, 2013
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
Is the sony DAV FC8 HDMI capable, if so how?
Apparently not.
Examination of any hit after a web search for "DAV FC8 features" answers it in the negative.
It has NO digital interfaces.
Jul 14, 2011 | Sony DAV-FC8 System
Trying to connect HDMI
Only a LCD or a Plama tvs have the capabilities of the HDMI hubs to do the connections for the HDMI cable.Standard CRT tvs can't get HD signal or have the capabilities of the HDMI hubs for the HDMI cable to connected to it.
Apr 24, 2011 | Broksonic Televison & Video
Im not getting anything (soud or picture) with the red, yellow, and, white cords. thats because it is set for the HDMI cable. how do i get the picture to come in without a HDMI compatable TV?
Sounds to me like you will need to plug the PS3 into a HDMI capable display and change the output settings on the PS3 to composite / AV.
Then reconnect to the non HDMI TV. The red, yellow and white cables should now work.
Mar 20, 2011 | Sony Playstation 3 (PS3) Console
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
Cant change my display settings from the 480i input
Whay kind of cable are you hooking it to your TV with...?
The one that comes with the ps3 is only capable of NTSC, or 480. If that is the cable you are trying to use, you will have to get an HDMI cable, or the component cable (the one with 5 rca's plugs, 3 vid 2 audio), as these cables are capable of the full 720 and 1080 resolutions.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
PS3
Avr 745 HDMI only output 1080i not 1080p. Your PS3 is capable of 1080p. You have to adjust your PS3 to 1080i then your screen will work. I hope Harman will come up with the upgrade for HDMI that can output 1080p otherwise you have to suffer or stuck with 1080i. Hope this will solve your problems.
Oct 14, 2007 | Harman Multimedia AVR 745 Receiver
Sony Playstation 3 (PS3) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
