My date and time not update it always return back?
    Scholar:
  • 36 Answers
Hello Jennybabe,
I believe that your motherboard may need a new battery for internal clock. When your turn the computer, it takes a long time to boot up would indicate that the BIOS system is loosing it's internal stored data including the time and date. First unplug the power cable from your computer. Look on the motherboard for a sliver colored coin shaped battery. It usually is toward the rear of the motherboard, The battery will be mounted in a holder with two spring arms to hold it down. Look on the side of the battery facing up. It will have a number on that starts with the letters "CR" and some numbers, perhaps 2330. So the whole number would read "CR2330". Purchase the new battery from a computer shop or from Radio Shack, sometimes a drugstore will have them. Remove the old battery by placing a fingernail on one of the spring arms and pushing it open. Now use a fingernail on the the other hand to lift the the old battery out of the holder. Do not force, if all is right the battery will just lift rout easily. This is slightly complicated and can be frustrating at first. Now take the new battery, holding it by the sides, slide it into the holder toward the bottom of the holder. When the battery is firm to the bottom of the holder press the upper edge of the battery down into the spring loaded arms. They will snap into position and hold the battery into position. Now replug the power supply cord into the power supply. Reassemble the machine and turn it on. Reset the time and date and use the machine for a while. now turn the machine off and wait through one of your favorite movies. Now turn the machine back on and verify that the machine does not stop for time and date entry. If it does that the clock section of the motherboard is damaged. If this happens then the only solution is to replace the motherboard. If there are further problems please retunr here and post them. Hope that this helps.
Posted on Nov 29, 2013
2 Suggested Answers
  • 34 Answers
SOURCE: update of time and date
Almost certainly you need to replace the battery on your motherboard. Radioshack will carry the part.
If my advice was helpful please vote for me!
Posted on Nov 16, 2007
Automatic Computer Date/Time updating
YOU HAVE TO SET THE CORRECT TIME IN BIOS.
DAYS,HOURS AND SECONDS.
Jun 04, 2013 | E-Machines eMachines Desktop PC
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
Unresponsive usb and sound
Did you try the system restore to go back to a date where you were before the updates? I have had this issue and that worked for me---those window updates can cause problems.
The updates can I believe be manually deleted or removed but I have always used the system restore to create a date and set it back to that time.
May 16, 2012 | Computers & Internet
Computer wil not load all the way at start up when you turn it on l
Hi, switch off.
Turn back on at first sign of startup, press F8 and hold till puta gives you a series menu's in safe mode.
Click recovery, when screen gives you the choice, choose a date before your most recent update download?
This is a common niggle when downloading routine updates, they don't always work first time.
Tip. when downloading updates, do yourself a favour and download one at a time. Boring I know, But I'm fedup with having to turn back to a previous screen. Hope all assits?
May 12, 2011 | Computers & Internet
I have the Logitech Harmony 880 and need the current calendar year and time to reflect appropriately. Currently, the calendar year is only displaying 2009.
Make sure that you have stepped through the entire process of setting the current date and time using the Systems Option menu on the remote. Note that it appears that some firmware updates leave you with an option to select AM or PM hours from the System Options-->Set Time. However, the most recent firmware update seems to have removed this ability, so only a 12hr clock is shown, and there is no option to set AM or PM. The clock will always default to AM. So, one workaround is to simply set the time before noon! Also, the remote will pick up the correct date and time when connected to the computer (assuming your system clock is correct) and you update the remote. Hope this helps!
Mar 09, 2010 | Logitech Harmony 880 LCD Remote Control
My Notebook time and date is always returned back to January 10, 2010.
Set the time inside Windows..If this will work..Go to the BIOS and manually set the time..If this will not work..You need to purchase a new CMOS for the Computer..CMOS is faulty..
Feb 03, 2010 | Microsoft Windows Vista Business Edition...
Nokia 6280 time and date
1. time and date - it sounds like the backup battery is dead - have it replaced and update the firmware.
2. puk2 is a sim release code - u have to take it from ur line servoce provider, (orange, vodaphon, at&t ...)
Nov 20, 2007 | Nokia 6280 Cellular Phone
Update of time and date
If you change it in the bios. make sure you save the settings.
If that doesnt work the battery may be bad.
Nov 16, 2007 | Intel D101GGC Motherboard
*ist-D date/time setting problem
I had exactly that problem with my first *ist D. Replace the AA batteries and the time was always lost. A new 'button' battery didn't fix the problem. The camera was replaced. The second camera had to be returned too. While I was with the dealer he told me my first camera wasn't really faulty as Pentax UK had been able to tell him how to fix it by some routine. I must admit I didn't listen hard to what he said, I was more interested in getting my hands on the third camera - and then the fourth when that didn't work either.
Sep 08, 2005 | Pentax *ist D Digital Camera
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
