Question about Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
Snowblower starting problems - Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
  •  John
    John Dec 07, 2013
    Hi jeffrey l jay, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
I have a sears snowblower and cannot remove the pulley, the bolt and are one.
Posted on Dec 30, 2013
  •  John
    John Dec 31, 2013
    Is it a Craftsman snowblower with a Tecumseh engine?
  •  John
    John Dec 31, 2013
    Add a CommentI'll need the model # of the snowblower and the model # of the engine along with it's size(HP)
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Snowblower wont start
Check out this YouTube Video. It will show you how to disassemble and clean the carb for the Honda HS520 snowblower.
http://www.youtube.com/watch?v=4i14aB6g798
Dec 04, 2013 | Honda Carburetor for HS520 Snowblower
Yardworks snowblower problem engine no starting
check out the interlock switch system, check battery with a load meter first to make sure battery is up to snuff
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
Troy bilt snowblower 123cc starting problems
Carburetor might be gummed up with old fuel. I would recommend carburetor overhaul. That should be the fix. When storing your snowblower till next use, either run the engine until out of gas or add fuel stabilizer to fuel tank to prevent fuel break down that causes damage to carburetors when not used for a long time.
Dec 30, 2012 | Garden
The snowblower starts great, but then it will not shut off. have to snowblow my neighbors, waiting for it to run out of gas
Try lowering the choke all the way below Turtle Speed. With any luck this will shut the snowblower off.
Mar 07, 2011 | Sport & Outdoor - Others
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh) Logo
178 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
