Question about Seagate Computers & Internet
Power for backup plus
What ids the power supply model number an name
    Scholar:
  • 36 Answers
Hello Allen,
We need further information to get you a replacement part number for your Seagate Backup Plus portable drives. Most of the newer ones run off the power from the USB cable. We will need the model number and power consumption in amps from the label on the unit. However, if the amps is 2 and the voltage is 12 volts then Amazon carries the power adapter, please see the link below. If tghere are further problems please return and post them here. Hope this helps.
http://www.amazon.com/Stca1000100-Stca2000100-Stca3000101-Stca4000100-Stcb2000100/dp/B0078PY0KG
Posted on Nov 29, 2013
What the differences of different hardware version?
TN11SCC TN16SCC TN21SCC TN22SCC TN23SCC TN51SCC TN52SCC TNK2SCC Specification Power consumption:
27W Power consumption: 32W Power consumption: 14W Power consumption: 10W Power consumption: 10W Power consumption: 18W Power consumption: 23W Power consumption: 26.7W Appearance Has shelf ID LEDs on panels - Applicable to case-shaped equipment Applicable to case-shaped equipment Applicable to case-shaped equipment Has shelf ID LEDs on panels Has shelf ID LEDs on panels Has shelf ID LEDs on panels Fuction - Provides various auxiliary interfaces and management interfaces.
Provides eight DIP switches for setting the subrack ID. Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. Supports OSN 3800 V100R007 and later versions together with their feature.
Not support SCC data backup, IP over DCC, subrack cascading, and power supply backup. http://www.thunder-link.com/TN52SCC_p317.html
Sep 02, 2016 | Gateway NV5213u (LX.WDM0X.001) PC Notebook
Can you supply the user manual for this player?
You will need to supply the brand name and model number. My suggestion is to use a search engine with (using quotation marks, but leave out parentheses) "(brand name)"+"DVD player"+"(model number)"+manual+pdf.
Be sure to use that exact wording and the plus signs and quatation marks. If the manual is available, you should be able to download and print it. Please DO print out your manual in case you need it again or give the DVD player to someone else who will need the manual.
Also, isn't this a good lesson about NOT throwing your owner's manual away with the packaging?
Aug 29, 2015 | Televison & Video
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Replaced graphics card now monitor and keyboard does not work
    Need to know;
    A) What is the computer manufacturer name, and model number,
    OR;
    what is the motherboard manufacturer name, and model number?
    B) What is the manufacturer and model number of the graphics card?
    C) Am I to understand you replaced the Power Supply?
    1) Manufacturer name and model number of it also.
    2) Is it new, or pulled from another KNOWN to be working computer?
    D) What was the original problem?
    Why?
    1) Want to make sure it's the correct graphics card for the motherboard.
    2) Want to make sure you have enough power out of that Power Supply, to not only support the graphics card, but the rest of the computer system also.
    Motherboard, Ram Memory, Harddrive, Optical Drive/s, Fans, etc.
    3) Need to know about the original problem, to help determine the solution.
    I need All questions answered. Post back in a Comment.
    Regards,
    joecoolvette
    Mar 01, 2013 | Computers & Internet
    Does the prostar 816 plus have caller id?
    It does have caller ID however you need to check that your call carrier is supplying inbound CLI. check on your handset that it is set to show this by pressing TRANSFER 119 then use the volume key to set it to show name or number first. check out http://www.abbeytelecom.com it has loads of Samsung DCS programming and training videos, I posted one as a example for you
    Feb 03, 2011 | Samsung Prostar 816 Phone
    I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
    The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
    If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
    Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
    Lost both the Wall AC charger and the DC car charger. Xantrec does not sell either from their website. Xantrec Xpower 200 plus
    Try Ebay, sometimes they will have aftermarket ones listed
    Go by the output and the style plug in for yours with the model name of your system
    Jul 24, 2010 | Xantrex Technology XPower Powerpack 200...
    WHat size battery goes in a SmartLink SLP-1000P
    corli, You will need to disconnect the SLP-1000P and open unit to find out the name and model number (battery number) of the batteries used in this unit. The company that made this UPS backup supply is no longer in business. Good luck. 12fixlouie
    Mar 13, 2010 | Smartlink Computers & Internet
    TI-83 Plus ram cleared message when turned on
    It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
    1. Check that main batteries are good and inserted in calculator.
    2. Turn calculator OFF.
    3. Replace the backup battery.
    4. Turn calculator ON.
    5. Press the [CLEAR] key to erase the "Ram Cleared" message.
    Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
    POwer supply failure
    Hi John,
    Had the same problem with a WD Elements 320 GB drive, and found a WD customer service number. They are sending me a FREE replacement. I have put the details on a message somewhere on this site, but can't direct you to it.
    The number from Australia is : 1800 429 861 ( routed to Singapore )
    Email Address : Western Digital Customer Service . CustomerService@wdc.com
    Send them details of your mailing address, drive model and serial number, and a description of your power supply. ( my power supply had a model number moulded on the back )
    Hope this helps
    Brbull
    Dec 15, 2008 | Western Digital Elements powered by WD 320...
    Computers & Internet Logo
    63 people viewed this question
    Top Seagate Computers & Internet Experts
    Computer Links
    Steve
    terminalcon
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
