Question about Microwave Ovens
How to grow capsicum - Microwave Ovens
  • Microwave Ovens Master
  • 2,113 Answers
Wikipedia This article is about a genus of plant. (thousands of types) For bell peppers, see Bell pepper. For the hot varieties, see chili pepper
Is chili pepper what you meant? If so what country/state/province are you in? It may have bearing on how to answer.
Posted on Nov 29, 2013
Coating coming off inside bottom of microwave. Safe or not
not ideal but not unsafe to use unless it grows into a big hole and leaks radiation... if it's a public use microwave it'd be condemned... think about looking for a replacement, they're cheap enough now compared to what they used to cost.
leaving the door open for a few mins after cooking will disperse any residual moisture and prevent this from happening in your next microwave. (it'll also slow down the rot in your current oven)
don't forget to vote on your answers to keep the site free.
Good luck.
Sep 04, 2017 | Microwave Ovens
Is chicken covered with Salmonella?
There is a possibility
http://www.abc.net.au/health/thepulse/stories/2014/12/04/4142326.htm
in correct food handling causes the bacteria to grow to dangerous harmful levels.
http://www.chicken.org.au/files/_system/Document/ACMF%20Food%20Safety%20Fact%20Sheet%20lowres.pdf
Oct 29, 2016 | Microwave Ovens
My kenmore microwave decided to stop heating!! It's less than 1 year old whats the problem??
Any piece of gear with electronics it can have an early failure. It's possible that the fuse for the high voltage circuit has failed or even the magnetron or the diode that produces the DC for it has gone south. I have the ugly feeling that these don't have a year's warranty anymore but it would be worth checking. I'm growing tired of Chinese quality.
Mar 27, 2011 | Kenmore Microwave Ovens
My GE White Spacemaker Microwave just stopped heating-you hear the motor running but the light inside grows bright to dim by a few watts while going thru any cycle of heating. Any answers?
The magnetron has probably failed, there are also two other parts that can be a factor, the high voltage capacitor and diode, the high voltage is generated by these items which in turn heat the food.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
Microwave display light is very dim model JMV8208BCB
The display is growing weak. It cannot be replaced separately as it is part of the control board. Sometimes removing the control board and cleaning the display and the inside of the cover will help some if it has a smokey appearance. However this is best left to a professional.
Jun 21, 2010 | Jenn-Air Microwave Ovens
My Frigidaire microwave wont heat up but the timer and lights work. When i press start, the timer starts but there is no sound and it doesnt heat. The microwave is less than a year old.
this may be another bin job, if its not heating up its likely to be the megotron,, thats one of the pricy bits that go out like a light bulb, ask if your shop sells the tester that you put into the microwave to see if its pushing out any radition at all, if its not i would bin it and get a new one, dont try fixing it yourself,,,,,,
you could kill yourself, there is well over 1000 volts floting about inside the unit, tuch the wrong bit and you grow wings prity fast, be warned
Oct 20, 2009 | Microwave Ovens
Type s333 2006 microwave will not heat. Everything is good but the microwave don't heat
this could be a number of things, fuses, megortron, capacitor,
but what ever it is dont try to fix it yourself there is over 1000 volts kicking about inside it and if you tuch this your going to grow wings prity fast, have you ever seen a stun gun working? well inside your microwave it there very big brother!!!! but it dont stun,,, it kills
look at it this way,,, whats your life worth in £????? play it safe,,, call a guy in to fix it for you, ok
Oct 20, 2009 | Panasonic Microwave Ovens
How to make pizza in oven
buy a pizza base...its readily available in d market. put it in d microwave for 5 mins then grate some mozzarella cheese and put on top of d pizza base...den put some vegetables...like capsicum, tomato, olives, etc.. again put it in microwave for 10 mins... if needed den put again for some more time, put some ketchup on top.. n ur pizza is ready
Jun 16, 2009 | LG LMH1017 Convection Microwave Oven
Everything on oven appears to work, but does not heat.
from what your describing it sounds as if you have burnt the antenna off of the end of the magtube if this is the case if your microwave is no longer under warranty due to the cost of the part you may be better off to purchase a new microwave.
Mar 25, 2009 | GE JE1540 Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
