Question about Garden
I need a complete bearing housing assembly part number 153598
  • 35 Answers
The bearings can be replaced without replacing the housing,snap rings hold them in place,numbers are on the bearings.match them up at a napa parts house,. a lot cheaper that way .
Posted on Nov 29, 2013
Removing the cutterhead onan elu thicknesser jointer to replace the bearings?
It is a long time since I encountered the Elu brand. I had to junk some Elu stuff 30 years ago due to inability to obtain spares. At least bearings are mostly standard items that can be sourced from many suppliers.
I haven't replaced bearings on an Elu jointer but the design and construction is probably similar to other brands so the process is largely intuitive using the usual techniques - warming plastics, aluminium housings and using bearing pullers when appropriate.
If all else fails keep removing bits until the part you need is what remains. Often that is the only method that works due to such tools being designed to be assembled in the least possible time and least possible number of operations. Sometimes the construction is downright sneaky...
It doesn't matter if the original bearings get knocked about or stressed by the removal process but ensure the new bearings are treated gently and not stressed by pressing only on the inner race to fit on a shaft, the outer race to fit into a housing or alternatively warming a housing will ease assembly.
Sep 06, 2017 | Masonry Tools
What is causing a whistling sound when the lg dish washer is in wash or rinse cycle but not when emptying wash or rinse water?
This does sound like the problem caused by the washer motor front bearing. The sound is more a whining sound. The bearing is of poor china quality and does start giving problems due to the water seal of the impeller that has the smallest water leak. The drop of water ends up on the front motor bearing causing the bearing to eventually pack up. You need to replace the water seal that is in the plastic impeller housing. Also replace the front motor bearing and this bearing is relatively cheap. Not necessary to replace the complete motor and impeller housing. Just the bearing (number 608) and the water seal (impeller housing includes seal)
Oct 09, 2014 | LG Dishwashers
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
I need to get into the houseing part to oil are clean it does not follow the hose . It starts to then stops.
Here's how to open the motor assembly.
1) Use a 5/16 nut driver (or flat screwdriver) and remove 5 screws holding body to motor assembly.
2) Use pliers to hold the worm bearing assembly where the tee screws in. Hold worm bearing and remove tee.
3) Use a 3/8 inch allen wrench to remove the worm bearing assembly. The allen wrench is placed in the same hole where the tee was located. (Removing the worm bearing assembly allows you to separate the upper motor housing from the lower housing.)
Use care when removing the top and bottom halves as sometimes the small flat washers tends to fall off the shaft when you open sections.
When screwing worm bearing assembly into the lower motor housing, you are screwing brass into plastic. If over tightened, the housing will split. Rule of thumb: tighten until it feels snug then go a 1/4 of a turn.
Jun 21, 2012 | Nelson Sprinkler: Traveling Tractor
Need to replace rear shock and strut assembly. I need a diagrahm of parts and any helpful hints.
Parts houses sell a complete assembly now,(spring and strut W/bearing) Much easier to replace the assembly,that way you don't have to compress the spring. Plus that way the factory ride height is restored.Just the 2 bolts at the lower mount and 3 nuts inside the rear cargo area.
Nov 14, 2010 | 1995 Buick Century
I have a Payne, Gas heat/Electric cooling unit, model# PY1PJB____, and apparently I need to replace the combustion blower wheel. When I turned it on 1st time this season, it made a very loud noise, and...
Hi, you will need to replace the inducer/combustion motor as one assembly. If you know any contractors that have a c-20 or c-38 license, you could get it at any wholesales a/c & heating parts house. If not, you will need to buy one on the Internet, just enter the name, model, serial number of this unit, and you can order one. Or, take the assembly out and go to a appliance parts house, they may have it in stock. Very easy to replace.With the wheel broken that way, I am sure you have bearing problems that caused this problem, so I would get the complete assembly. You will be better off in the long run.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
PS, please rate me, and keep me posted on the out come. Thank you.
Nov 08, 2010 | Heating & Cooling
2004 ford explorer tire bushing on front tires, when taken off cant see where to lube them? does anyone know??? Leave me a comment at prbonz71@aol.com
There are no "tire bushings". There is a complete front wheel bearing assembly that if bad, will need to be replaced. There are also no lube fittings on any of these assembly's. You need to remove the entire brake assembly, rotors, calipers, and caliper mount just to get to the nut for the front wheel bearing. Then you have to take cotter pin out of the main nut on the end of the axle, and take off the nut locking nut, you will need a 32mm socket, (if memory serves me correctly) to take the axle nut off. Then there will be 3 bolts on the back side of the axle housing that will need to come out, unplug your electronic brake wire, and the wheel bearing should fall right out.
Mar 22, 2010 | 2004 Ford Explorer
Leak between outer bearing and plastic drum housing.looks like factory assembly defect .
It is wear in the bearing housing that is causing the problem
Only solution would be to replace the complete outer drum assy
An expensive repair..
Jan 28, 2010 | Hoover Washing Machines
I have a 2002 ox66 Yamaha 2 stroke 250 hp std rotation outboard. The propshaft snapped off. The fluid is clean and remaining shaft spins freely. Can i remove the two flange screws and carrier and pull out...
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Nov 15, 2009 | Boating
Can't get the drum shaft from outer shell
Toddah email me at aliikoa-2000@msn.com, I am on the road, but do have the part number for the complete assembly already to put in, just to tired to walk out to the truck after 14 hours.
Sep 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
