Question about HP ProBook 4510s FM849UT Notebook
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
Just above the mousepad on the laptop is a very small hard to see button, pressing this will disable and enable the mousepad. if this doesn't work you can use the "fn" key and usually f5 to enable it. if that doesn't work you most likely need to install the drivers for the hardware.
Posted on Nov 29, 2013
  • HP Master
  • 7,627 Answers
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
  • 1752 Answers
SOURCE: Hp 4510s probook will not power on
Your battery is shot.
Posted on Nov 03, 2009
SOURCE: why windows xp won't shut down in hp probook 4510s
Just delete webcamera software or use default driver for it
И будет тебе счастье
Posted on Mar 25, 2010
  • 10 Answers
SOURCE: Hp probook 4510s power button blinking won't start
maybe out of power and the dc jack is broken take the battery out and if the light dose not flash then go chance its the dc jack.
if with out battery still blinks then there's a short on mother board and or video card is bad. but some times taking out that battery will reset the m/b and get it to work if you are lucky
Posted on Aug 31, 2010
SOURCE: I have a Compaq presario
Just double tap the same area ie the light that came on when you did it the first time.
Posted on Nov 01, 2010
MSG-CPC
  • 1325 Answers
SOURCE: How do I replace LCD Screen on HP Probook 4510s?
hi
according to the S/N, this notebok has several options for the display with webcam
HP p/n 535851-001 or 535852-001, 535853-001, 535854-001, or 535856-001
you need to take the upper logic top cover , remoce the screws that hold down the keyboard. disconnect the webcam connections and the LCD invereter connectio. Remove the hinges that attach the LCD to the top cover, remove the bezel from around the LCD panel. There will be or mya not be some screws to remove to the LCD from assembly top cover.
this is basically it.
if you need more information, let me know -- i can get some other assembly isntructions for you if required. But let me know which LCD p/n it is you require.
Posted on Dec 09, 2010
Unlock the mouse pad on my hp laptop?
Try double tapping the upper left hand corner of the screen.
Feb 21, 2015 | HP ProBook 4530s Notebook
Hi i have hp laptop ProBook 6460b for windows 7 and my mouse is locked, there is a little orange light on the left of touchpad and i cant move my mouse, can you help me please, because i can't wor
Hi! I have the solution! I know it's really late. double tap the light with your finger.
on the touch pad in the upper left corner, the light is glowing, when you double tap it it will lock the mouse pad. do it again and it un-locks it :)
Apr 22, 2012 | Computers & Internet
How do I disable the touchpad on my hp probook 4530s?
03-27-2013 FINALLY A SOLUTION THAT WORKS TO DISABLE HP 4530S touch pad:
Clickity click on Control Panel/System/Device Manager/Mice/Synaptics PS2/Driver/Update Driver/Search Internet for latest driver.
It should find and update with driver dated 01/10/2013 which is driver version 16.3.9.0
HOORAY! Double click on the upper left hand corner of the mouse pad, the light comes On indicating that the mouse pad is OFF - and it works just like HP said it would two years ago. Knowing HP, who knows for how long it will work.
This works on Windows 7 - on other systems your milage may vary.
Dec 11, 2011 | HP 2133 Notebook PC
How to fix my hp mini5101 touch pad, it's not working
try using an external usb mouse then try an repair your touch mouse
Sep 12, 2011 | HP ProBook 4510s FM849UT Notebook
In my Probook 4510s, the Left Click Moouse button functions as the Right Click one.
first open control panel there u will get the option of mouse please tick out this option " switch primary and secondary button ".
Sep 09, 2011 | HP ProBook 4510s FM849UT Notebook
The mouse pad on my laptop has been automatically disabled and i cannot get it back
There should be a small button / On-off switch just above or beside the mouse pad which somehow has been turned into OFF mode which is why you are facing this issue.
Please switch On the button and you will be able to access the mouse pad.
Aug 02, 2011 | HP ProBook 4510s FM849UT Notebook
Hi. i have a HP 4510S probook There is an intermittent problem with the mouse where during start uo it says 'mouse not detected' When it does work it's usually for a short while & then...
Do you use touchpad? If so, have you tried reinstall touchpad driver? to get driver for Windows XP, go to here. For windows 7 the touchpad driver isn't listed.
May 25, 2011 | ASUS Eee PC 1000HE Netbook
Hp pro books courser is not working. there is little orange led lightt just a corner of the touch pad ?
That light is used to indicate whether or not the touch pad is activated. There will be a button nearby that can turn the touch pad on and off.
Mar 03, 2011 | HP ProBook 4510s Notebook
HP ProBook 4510s FM849UT Notebook Logo
102 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
