Question about Skylink Group Skylink Technologies Universal Garage Door Transmitter (G6V)
Forgot code on skylink 89
How to reset keypad code
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
I forgot my nokia's keypad unlock code what should i do
basically keypad codes are security codes.... you have use master reset code to reset your mobile and set new keypad code for it .. get the master reset code at www.theunlockarena.com..
it cost reliable
May 11, 2010 | Nokia 3110 Cellular Phone
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
How to open nokia 6600 in keypad?
my 2 5 8 * keys are not working properly
Dec 27, 2009 | Nokia 6600
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you reset or access keypad of used 1998 Crown Victoria if never had the keypad code.
u must have the old key pad code to reset the a new code, the code for the keypad is on a paper tag located on the keyless entry module.
Jun 17, 2009 | Ford Crown Victoria Cars & Trucks
Keypad code will close the door but not open it.
check that both codes (in the remote & garage door opener) are the same. Press reset on the opener and reset enter the code.
Nov 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Skylink Group Skylink Technologies Universal Garage Door Transmitter (G6V) Logo
37 people viewed this question
Top Skylink Group Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Skylink Group Building Material Expert? Answer questions, earn points and help others
