MY PHONE LINE SHUT DOWN AND I HAD TO RECONFIGURE MY ROUTER AND BECAUSE ROUTER NETWORK NAME AND SECURITY KEY CHANGED, I NOW NEED TO RECONFIGURE MY WN3000RP EXTENDER
  • Computers & ... Master
  • 7,993 Answers
Normal. If router is reset to defaults, you must reconfigure the router.
Posted on Nov 29, 2013
Junoon007
  • 1011 Answers
SOURCE: setting a new network security key for my Netopia 3341 wireless
check this link sir
Posted on Nov 26, 2008
Joed911
  • 4338 Answers
SOURCE: I need to change network name/ssid. the ip
Linksys reset
reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Posted on Sep 06, 2009
bschilz
  • 2049 Answers
SOURCE: Forgot my security password (network key)I need to
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
Posted on Nov 21, 2009
  • 10406 Answers
SOURCE: Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Posted on Jan 01, 2010
Testimonial: "Need more info...Thank you."
DRAGONF1R3
  • 115 Answers
SOURCE: Hi,
All of that information is what YOU need to know. The security type and security key are things you would choose when you initially set up your router.
To find your SSID go to Start> Run> type CMD at the prompt type ipconfig copy the default gateway in your address bar.
Your information should be:
User name: (Leave Blank)
Password: admin
unless it has been changed already.
Go to your Basic Wireless Settings and you can find your Wireless Network Name (SSID) column. On there you can edit your SSID.
You can then click on the security tab and that will tell you what security type you use. It won't show your password, it will show ***** so it will only show the # of digits. That may jog your memory. You should be able to change your key too.
hope this all helps.
Posted on Jan 26, 2010
Reconfigure netgear EXTENDER
Try typing http://mywifiext.net/IA_frame.htm in your browser. This should bring up the start screen for your device. From there you can go through the setup wizard. If that doesn't work, you may need to run through the reset procedures for the device and then try. If that still doesn't work, turn off wireless on your computer and run a network cable directly into the extender from your computer and try again.
Nov 29, 2013 | Computers & Internet
Need network security key
Only you have the security key. You can reset to default settings by pushing and holding the RESET button for 30 seconds or so. Then reconfigure SSID and Security code. You may want to write down the password somewhere.
Dec 22, 2012 | NetGear N300 Wireless Router
What will i do if i forgot my security key???
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
In case you have forgotten the User Name/ Password of the router, there is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | D-Link AirPlus DI-524 Wireless Router
Please help me!! i dont know how to get mt network security key and i cant connect to the internet cause i have to have to have the network key!!
Look on the back of the router/modem and press the little RESET button-hold it down for about 15 seconds. This will reset the unit back to default settings.
To get back it back up and working again, click here for the manual, and other support services:
http://www.dlink.com/products/?pid=567
Hope this helps.
Mar 06, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Reconfigure router
I seriously can't stand those motorola routers specially since they have to reboot themselves after every change.
Unplug the power from the router, hold the reset button in and plug the power back. Keep holding the reset button for 30 seconds. That should restore it back to factory settings. Plug one machine to the router and try to access the admin console. if memory serves me correctly, the user name is admin and password is motorola.
Jun 14, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Computers & Internet Logo
David Payne
David Payne
