NOISEY START BUT IT HAS STARTED CAR RUNS WITH OUT ANY NOISE
  • 818 Answers
It depends what you mean by noisy start. If it is a high-pitched squeal when you start (or accelerate quickly) it may be the alternator belt that is worn and needs replacing. The squeal of a worn alternator belt usually wears off after a few seconds because the belt has 'warmed'.
If it's a 'tapping' or 'clicking' noise there are 2 possible culprits: Big end bearings (on the crankshaft) or camshaft. If the big end bearings are worn or the camshaft 'buckets' (followers .. those things that cause the inlet and exhaust valves to open) they rattle - metal against metal. After starting the car oil finds its way between the worn metal and silences the noise.
A 'grinding' noise may be caused by the starter motor/ring gear.
Posted on Nov 30, 2013
Kenmore Frig noisey & runs a lot
First, never turn it off, the frig runs to reach temperature as set on the thermostat. The rattle may be caused by a loose fan cover and you may have just solved the problem. as for RUNNING all the time, a common cause for prolonged running are dirty and clogged condenser coils. Clean coils with a brush and VACUUM
it will probably solve th eproblem.
Dec 22, 2014 | Kenmore Refrigerators
Lifters making noise
you sure its lifters not exhaust leak , those hemi s are known for broken exhaust studs,if the lifters r noisey try some 5/20 oil
Mar 01, 2014 | Dodge Durango Cars & Trucks
Vectras problems
need more imfo. but I'd say its the starter , or flywheel if it only does it when you start it.
Nov 29, 2013 | Computers & Internet
In regards to the 1998 Jag with the whirring noise
Posssible power steering pump noisey. have a shop listen to the noise you say you have.
Aug 28, 2012 | 1998 Jaguar XK8
2002 mazda protege - 2.0l - car sat for a week and when started alternator belt squeeled and ate some belt up. Now it seems ok. Bad alternator or bad water pump?
could have been a loose belt to start with. check alt and water pump. if alt is not noisey and charging. check water pump for leaks and noise. make shore belt is in good condision and the correct tension
Jul 17, 2010 | 2002 Mazda Protege
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Ticking on '05 Chevy Equinox
THE TICKING NOISE IS VALVE LIFTERS.MOST OF THE TIME WHEN ENGINE OIL GETS DIRTY NEEDS OIL CHANGE.DIRT GETS IN LIFTERS THEN CAUSES THEM TO BE NOISEY.IF LIFTERS STAY NOISEY ALL THE TIME.THEY OR WORN AND NEED REPLACING.ITS NORMAL FOR CAR TO SMOKE A LITTLE WHITE SMOKE IN MORNING ON START UP.LONG AS IT DONT KEEP SMOKING IF SO.YOU HAVE HEAD GASKET LEAKING.
Oct 23, 2009 | 2005 Chevrolet Equinox
I have a 2003 Mercedes C240. When it starts up there's a humming noise that quits after a few minutes, but when the car starts moving it starts clicking.
THE HUMMING NOISE IS YOUR SECONDARY AIR INJECTION PUMP. THEY TEND TO BE NOISEY AT START-UP. IF IT IS NOT WORKING COREECTLY IT WILL SET A CHECK ENIGNE LITE. THE CLICKING NOISE IS NORMAL IF IT GOES AWAY AFTER WARM-UP. THESE MOTORS ARE NOISEY WARMING UP DUE TO THE HYDRAULIC LIFTERS.
Mar 21, 2009 | 2003 Mercedes-Benz C-Class
Upon start up, have what sounds like valve train noise
SOUNDS THAT YOUR TAPPETS ARE NOISEY COULDN'T TELL YOU IF ARE ADJUSTABLE OR THEY ARE HYDRAULIC TAPPETS NEED TO REFER TO HYUNDAI.
Dec 17, 2008 | 2001 Hyundai Accent
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
