Vectras problems NOISEY START BUT NO NOISE ONCE CAR IS STARTED
  • Lynn Mckenzie Nov 29, 2013
    Hi STEPHEN LESLIE HENDERSON, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • 35 Answers
Need more imfo. but I'd say its the starter , or flywheel if it only does it when you start it.
Posted on Nov 29, 2013
NOISEY START BUT IT HAS STARTED CAR RUNS WITH OUT ANY NOISE
It depends what you mean by noisy start. If it is a high-pitched squeal when you start (or accelerate quickly) it may be the alternator belt that is worn and needs replacing. The squeal of a worn alternator belt usually wears off after a few seconds because the belt has 'warmed'.
If it's a 'tapping' or 'clicking' noise there are 2 possible culprits: Big end bearings (on the crankshaft) or camshaft. If the big end bearings are worn or the camshaft 'buckets' (followers .. those things that cause the inlet and exhaust valves to open) they rattle - metal against metal. After starting the car oil finds its way between the worn metal and silences the noise.
A 'grinding' noise may be caused by the starter motor/ring gear.
Nov 29, 2013 | Computers & Internet
Noisey lifter on a 2000 Yukon Denali
your assuming is bang on wright
Aug 17, 2012 | 2000 GMC Yukon
Re Vauxhall Vectra 1.8 16v 1998, Power steering fluid leak from under the passenger foot well. How do I fix it?
First thing you need to do is pinpoint the source of the leak EXACTLY, clean off all the fluid and then put some fluid in the system, have someone start the car and while the car is supported securely off the ground go under and locate the leak, wear safety goggles so fluid doesn't get in your eyes.
Apr 05, 2017 | Cars & Trucks
Opel Vectra B model 1997 Gl 5d 1.6 wont fire up
Ok..for starters have you checked to make sure your getting fire to the plugs? Need to pull a plug wire off and check to make sure. If your getting fire then your problem lies in the fuel delivery system...if not then it would be in the ignition system...have you checked ALL of your fuses? Make sure that your fuel filter isn't plugged, and on the fuel rail you'll find a small port with schrader valve (similar to that on the tire)..you can turn the key to the run position and then push in on valve to see if your getting fuel to the rail..once you narrow it down to fuel delivery or ignition problems we can further narrow it down.
Mar 02, 2012 | Opel Vectra Cars & Trucks
2002 mazda protege - 2.0l - car sat for a week and when started alternator belt squeeled and ate some belt up. Now it seems ok. Bad alternator or bad water pump?
could have been a loose belt to start with. check alt and water pump. if alt is not noisey and charging. check water pump for leaks and noise. make shore belt is in good condision and the correct tension
Jul 17, 2010 | 2002 Mazda Protege
Noisey gear box. silent when clutch is engaged
change fluid first then go from there
May 27, 2009 | 2007 Ford F
I have a 2003 Mercedes C240. When it starts up there's a humming noise that quits after a few minutes, but when the car starts moving it starts clicking.
THE HUMMING NOISE IS YOUR SECONDARY AIR INJECTION PUMP. THEY TEND TO BE NOISEY AT START-UP. IF IT IS NOT WORKING COREECTLY IT WILL SET A CHECK ENIGNE LITE. THE CLICKING NOISE IS NORMAL IF IT GOES AWAY AFTER WARM-UP. THESE MOTORS ARE NOISEY WARMING UP DUE TO THE HYDRAULIC LIFTERS.
Mar 21, 2009 | 2003 Mercedes-Benz C-Class
Start up problem
If the belts are making noise, the alternator may NOT be spinning fast enough to produce sufficient voltage to charge ther battery, because the belts are slipping, and slipping = noises.
Tighten the belts.
Regarding the starter: Replace it, or get it overhauled at a starter repair service. You have bad starter contacts
Sep 30, 2008 | 2003 Toyota Corolla
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
