Question about Apple Logic Pro 6 (822914000569) for Mac
Key code for logic 7 - Apple Logic Pro 6 (822914000569) for Mac
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
I would recommend to buy Logic Pro X from the Mac App Store!
Posted on Apr 17, 2014
MY PRINTER SHOWS 5010 CODE HOW DO I CORRECT THIS PROBLEM PLEASE ?
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5010
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft ***'y (QL2-0936), Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Carriage lift sensor unit (QM2-3092). In brakets you have the part number for each one of them. Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when replacing the logic board ***'y.
Feb 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
The computer codes are 121155. What does this mean?
Code retrieval can be accessed by the ignition key or by a diagnostic readout box(DRB).To obtain the codes using the key method,set the park brake,and put the vehicle in Park/neutral.
Some 95 and later OBDII vehicles, you may be able to retrieve OBDII codes with this procedure, if equipped with digital dash:
* Turn the ignition key ON,OFF,ON,OFF,and finally ON again(ENGINE NOT RUNNING)
* The codes will start to flash on the POWER LOSS or CHECK ENGINE light.
* FLASH,pause,FLASH,FLASH=code 12
The codes showed are...
Fault Code 12
Description: Memory standby power recently lost
Power loss light: Off
Limp-in mode: None
Possible Causes:* Battery or power line recently disconnected - This code is normal if the electrical system has been worked on or the battery has recently been disconnected. It will be removed after 15 ignition switch on/off cycles.
* Low system voltage, bad battery or battery terminals - If the system recently had a power drop (due to a dead battery or bad alternator), this code will appear. If the battery terminals are bad and the engine was jumped, this code will appear.
* Bad connection or wiring - Check the wiring and connections between the battery, power module, and logic module (or SMEC). Check all fusible links and power connectors to the battery. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Diagnostic Method
Trigger Parameters
- Logic module receives power after previously not having power
Results If Component Fails
Fault code 12 is stored. The logic module is basically telling you that it has lost power and will not remember any previously stored codes or engine sensor table data. The code will be removed after 15 ignition on/off cycles and the logic module will use default values for all look-up tables as a starting point until it "learns" the attributes of the engine.
Fault Code 11
Description: Engine not cranked since last reset or no ignition reference signal detected during cranking
Limp-in mode: None
Possible Causes:
* Engine hasn't been cranked since last reset - Power was removed from the logic module (disconnected or dead battery, etc.) and the logic module has no memory of seeing a signal from the ignition reference sensor. Crank the engine and check for the code again. If the logic module saw a signal, the code will be cleared. This code will not show up if the sensor simply fails. The logic module must be reset and the engine cranked to see if the sensor is working.
* Bad connection or wiring - Check the wiring and connections between the hall effect sensor (located underneath the distributer cap) and the logic module. Check the continuity of the two 3 conductor cables coming out of the sensor--these are prone to fatiguing and breaking inside the insulation where they exit the sensor if the cables are not properly tied down. You may be able to resolder them. Clean and regrease any corroded connectors with dielectric grease and repair any shorts. This code will not show up if the sensor simply fails. The logic module must be reset and the engine cranked to see if the sensor is working (see above).
* Hall effect sensor failure- Check the ignition reference sensor and fuel injector sync sensor cables. They are the two, flat 3 conductor cables coming out of the sensor at the base of the distributer cap. These often fatigue where they exit from the sensor. Upon replacing the sensor, make sure the cables are clipped or tied to the distributor cap shroud (or elsewhere) so they do not swing around. This code will not show up if the sensor simply fails. The logic module must be reset and the engine cranked to see if the sensor is working (see above).
Diagnostic Method
Trigger Parameters
- Computer has been reset
- No signal from the ignition reference sensor has been detected
Fault code 11 is stored and the engine will not start (even if the ignition reference sensor is working). A running engine will stall, but no code will be stored. The logic module must be reset and the engine cranked to see if the sensor is working.
Fault Code 55
Description: End of message
Limp-in mode: None
Possible Causes:
* No further fault codes are stored. If this is the only code received, then there are no codes stored in memory. This code will always be given, even if nothing is wrong. If you do not get this code, then you may not be retreiving the codes properly, or the power loss light may be burnt out. The light should come on for 1 second when the ignition is initally turned on as a bulb test.
Diagnostic Method
Trigger Parameters
- No further codes in memory
Hope helps (remember comment and rated this)
Aug 03, 2010 | 1996 Chrysler Concorde
Nokia 6230 keypad problem
sounds like the phone got wet or was left inVERY humid enviroment Clean ALL corrosion from the contact points and the back of the phone's logical key pad(where the electronics are) other wise get it replaced....
May 28, 2008 | Nokia 6230
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Apple Logic Pro 6 (822914000569) for Mac Logo
47 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
