Question about HP f2105 21" LCD Monitor
Red line on monitor; unsure type of f2105 just know high def
I have an HP f2105 monitor and the screen has 1 red line about 3 inches in from the right side. I do not believe it is the computer as when you place the mouse on it the line is on top of the mouse.
    Guru:
  • HP Master
  • 829 Answers
The red line could be caused by the cable, or it could be a problem with the monitor. Pretty easy to test, though, just get another cable and swap it out.Sometimes the cable that snakes through the hinge gets worn causing display artifacts. Try flexing the hinge and see if the behavior changes.
Posted on May 10, 2009
I need to plug an HP f2105 monitor into an HP elitebook laptop
Elitebook has a vga port with is 15 pins. If the monitor only has DVI you can get a VGA-to-DVI-A cable. They are cheap and available on monoprice.com Make sure the monitor supports DVI-A
Make sure to check the DVI port on the monitor for the wide horizontal pin with two small pins on top and two underneath. See pic below.
Dec 03, 2012 | HP f2105 21 inch LCD Monitor
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
Screen shuts off after 1 second
You may have power supply failure due to bad caps, bad inverter circuits (shorted IC/Transisotrs/Transformers), or bad lamps assmbly.
You need to open it up and inspct the inside and report back. Please look at my picturesso you know what you are looking for, I will be uploading the pictures of F2105 this weekend (I have two of them that I am working on, one has bad lamp assembly, real hard to repair, another one has bad screen (vertical bars/lines)
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you see inside. See the bad lamps album also.
Apr 14, 2010 | HP f2105 21" LCD Monitor
First one and now 2 vertical lines on my HP f2105 monitor. Would this be the actual screen or a component that drives it? Thanks
Move the mouse cursor across the lines then check if it shows up fine. If it shows up fine, the problem is in the video card itself, not the monitor. It can be caused by VRAM or GPU overheating. Clean the video card thoroughly. Using a compressed air is a good alternative.
Oct 18, 2009 | HP f2105 21" LCD Monitor
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
Vertical lines in my laptop screen
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
The whole screen is shifted 1 inch to the left.
When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
Sep 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Thin blue line
What have they told you to do? This will help us in troubleshooting. Is this still under warranty?
Aug 20, 2007 | HP f2105 21" LCD Monitor
HP f2105 21" LCD Monitor Logo
137 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
