Question about Ovens
How to open a locked oven door
Whirlpool IBS650P wall oven lost power during a self-clean cycle and the door is now locked closed. I suspect a sensor or some other temperature device blew and now the door is stuck closed.
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Posted on Aug 24, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Feb 11, 2010 | Viking 27" Professional Select Built-in...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Jan 26, 2008 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
