Sport & Outdoor - Others Logo
A
Anonymous Posted on Nov 28, 2013
What dose the black wire do from the trailer plug ?
mikadot
Level 3:
  • Sport & Outd... Master 2,113 Answers
  • Posted on Nov 28, 2013
mikadot
Level 3:
Answers
2113
Questions
0
Helped
466322
Points
5959
Http://www.etrailer.com/question-5059.html
2answers
Trailer wiring 2008 Trailblazer SS
Sounds like the vehicle came with towing package. There should be 2 large wires and a smaller one. The blue "should" be trailer brake feed. The other large wire, usually the black, would be 12 volt power for trailer interior lights and battery charge. The red should be a smaller wire and it is the back up light wiring to the trailer. Most trailers don't use this wire, except for brake lock out on some boat trailers with hydraulic brakes. Also see http://www.etrailer.com/faq-wiring.aspx. All of this is used for5, 7, or 6 pin plugs.
tip
Wiring Different Trailer Types - Highlander
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery2_bing.gif, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
tip
Trailer Wiring Problems?
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
tip
Trailer Wiring
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
Red or Black (not both) = Battery, aux power - A
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
tip
Trailer Wiring 101
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
The following are the accepted standards for different trailer types.
The different plugs and connectors used are marked with either a number or letters. Having the functions of each in advance can save a lot of trial and error when troubleshooting..
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
tip
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 23, 2009 • 1998 Ford Explorer
tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 • 1987 Jeep Wrangler
tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 • 2004 Dodge Ram 2500
tip
Hello all,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 • 1981 Ford F 150
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
