Question about Kohler Canister Valve Center Toilet Guide
Can't get the canister to turn to pull it out
2007 Mercedes-Benz C230 Fuel filter location
It is located on the left side of the engine (same side as the supercharger) just off the firewall and next to the fuse box under the hood. It is a black canister with a hemispherical top with a plastic hex head on top (which I believe is 26mm). The hex head turns the entire canister to unscrew it.
The filter itself is on a shaft that pulls out of the canister once you get it out of the car. Its just snapped in place. Yank it off, then pull the filter off the shaft and replace the three O-rings and reassemble.
Feb 04, 2013 | Mercedes-Benz C230 Cars & Trucks
There is gas coming from the canister in the front left fender?
The canister is clogged. This is not very common. I would get a used one and it will be done.
The canister pulls fumes from the tank and turns them back into raw fuel. If the canister gets clogged than the vacuum hose pulls raw gas and fills up the canister.
Feb 21, 2011 | 1991 Oldsmobile Toronado
Loading film into it.
You pull down on the clip on the side of the camera. That will open the back of the camera. Pull out a little of the film from the canister. Put the canister into the side with the spindle. Put the end of the film that you pulled out over the roller on the opposite side of the camera then shut the lid and turn on the camera.
Jul 19, 2010 | Minolta F10 BF 35mm Point and Shoot Camera
Vacuum sounds funny and doesn't have any suction.
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have lost suction.....what do I do? -with the vacuum and the hose!
Its okay to unscrew where the hose is connect to the area close to the bottom, where the hose bends. That is where there is usually a ball of hair, dust, and whatever. Pull the hair ball out and also clean the roller.
Jan 12, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lack of suction
you should check the round filter casing on theleft and the right side of machine to make sure they are snaped in right also the clear hose on the bottom sumtimes comes unhooked.
Dec 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson seems to have lost suction?
If the usual clog clearing and filter cleaning doesn;t work-> I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Nov 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Doesn't seem to have as much section as when new. Is there some routine maintenance I should be doing?
Nov 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to open legacy canister
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Dec 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
I need to open the canister to change the switch
Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Dec 04, 2008 | Electrolux Epic 6500 Vacuum
Kohler Canister Valve Center Toilet Guide Logo
852 people viewed this question
Top Kohler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kohler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
