Question about OKI B4545 All-In-One Printer
The machine say replace toner and the toner is new
Thanks
  • 30 Answers
Try un-plugging (electricity) the machine sometimes this will re-set the memory.
Posted on Dec 03, 2013
AR5731 Undetected
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
How to solve add toner see instruction front cover to replace toner ricoh mp2000
If you just add toner and it just keep saying add toner. open sp mode.
Press: Clear modes>1-0-7>Clear/Stop> SP2 x x x- Drum > 214 -Developer Initialization>Exectute and wait.
please rate. thanks
Dec 09, 2014 | Ricoh Aficio mp2000 Copier Machine
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Appears cf70 by starting machin
[CF70] New toner transport motor abnormality
Check if the transport auger and paddle are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit).
Is the new toner transport motor disconnected?
Replace the new toner transport motor.
Feb 20, 2012 | Toshiba E-STUDIO 720 Copier
Brother MFC 9440 won't recognize new toner cartridge
I knew it needed to be reset to recognize the new toner. Glad you found the info in the electronic menu. Thanks for using Fixya. If my suggestion was helpful could you please rate it for Fixya. Thanks
Dec 05, 2011 | Brother MFC9440cn AllInOne Laser Printer
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
I have e-studio 355, machine is indicate low toner. I replaced new toner cartridge but the machine show "toner not recognize". I try to replace the ic at the back of the old toner cartridge and...
Do not go very far yet, the problem is with the toner so I recommend you do what the machine says before looking somewhere else. replace with correct toner.
If you have a friend with the similar machine which is working properly try and get their toner put in your machine if it works buy similar toner if does not then it is the machine. You can also try your unrecognized tone in another machine see the results. The problem is just toner and the sensors in your machine.
Jul 14, 2011 | Toshiba e-Studio 205 Copier
Kyocera 1500 LA error E33 what need to do? i am mexican so please help me in spanish if you can thank!!!!
E 33 means that the machine is out of toner. Please replace toner the machine will be ok.
Oct 13, 2010 | Kyocera Office Equipment & Supplies
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Gestetner 3222 toner
I take it that you removed the black cap on the toner bottle OK thats out of the way open the door remove the toner as you would to replace. Remove the toner bottle look inside the bell behind the green handle and check that you can see a claw type thing if you cannot remove obstruction. Refit the toner close door and wait until machine stops and see if toner light goes out. If not open door wait 15 seconds close door and machine will start loading toner again. You may have to do this 5-6 times if it doesn't work after this then likely thing is the toner motor faulty and will need replacing
Thanks J
Nov 27, 2007 | Brother HL-2040 Laser Printer
OKI B4545 All-In-One Printer Logo
32 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
