Question about Yamaha Electrical Supplies
Yamaha ef 1600 starts with starting fluid but wont start with gas
4 Suggested Answers
  • 62 Answers
SOURCE: I have a ef 2600 yamaha generator & over the course of a
The fuel pump diaphram has a hole in it.
Posted on Apr 07, 2009
SOURCE: yamaha ef 2400is starting
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
Posted on Aug 21, 2009
  • 31 Answers
SOURCE: Yamaha Portable Generator EF 1000
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Posted on Jan 10, 2011
Testimonial: "Good advice, thanks."
Yamaha blaster 2001
No fuel or no spark. Quick test: spray some starter fluid into air intake and try to start it. If it runs and then dies, you've got spark but no fuel. If the bike quit with no prior symptoms, check spark plug wire not knocked loose, fuel filter clogged. (You do have gas, right?)
May 20, 2014 | Sport & Outdoor - Others
Motor will run on starting fluid but wont stay running
Did it sit for a long time with gas in it?
Your idle jet(s)/circuit is plugged up.
When gas sits too long, the components start to separate, and it turns almost into a varnish.
This starts to plug up the jets and passages, starting with the smallest, which happens to be the idle circuit and jet.
Clean out the carb, paying attention to the jet and the passage drilled in the carb body.
Feb 10, 2014 | Yamaha Motorcycles
1994 yamaha 350 big bear wont start
hello
chack for spark in the plug.
if tou have a spark itts a gasolin froblem...
inject some gasoling with a seringe to the carborator 5-10cc and run it
if it starts. fix the carborator
give my a call
you can do this!!!
injoy
Dec 17, 2013 | 2002 Yamaha XV 1600 Wild Star
Yamaha kodiak 450
hows it run once started, is the choke working. could have a rusted choke cable. once again this crappy gas may have destroyed the gaskets inside which been a real problem especially with 2 strokes.
Jul 02, 2013 | Motorcycles
Gp 800 will crank but wont start
Hi, most likely the trigger coils near the flywheel, it will still have spark but the timing may be off. Try new plugs first as they may have spark outside the cylinders but not when under compression. Regards Phil
Jul 01, 2012 | Yamaha Boating
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Hi i have a yamaha fino scooter.. and it wont start. i've cleaned the carbi. changed the spark plug. checked that thers a spark. bleeded the feul line. and adjusted the throttle and idle. any...
Try some spray starting fluid.
That will prove whether or not the spark if ok.
Make sure there is gas in the carb.
The tank may be clogged or the carb float valve could be stuck.
Dec 20, 2010 | Yamaha DT 360 Motorcycles
2003 Yamaha Road Star 1600 leaks gas from underneath when I start it.
I take it when you say gas you are refering to petrol . gas leake ,don't use your bike untill its been repaired, many bikes have burst into flames through gas leakes .Remember petrol does not burn its the vapour given of that catches fire .
Mar 13, 2010 | 2003 Yamaha Road Star Silverado
I have a 2004 yamaha yz250f it will only start with starter fluid
check the carburator if there is a gas goes to it
Aug 30, 2009 | 2004 Yamaha YZ 250 F
Bike wont start
Are you getting spark? If not, ck ignitin coil and wiring
Jun 30, 2009 | 2003 Yamaha V Star Classic
Electrical Supplies Logo
52 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
