Question about Packard Bell iMedia Computers & Internet
No sound device, just multimedia device after adding a new hard drive and Windows XP reinstall.
Hi, just wondering if my sound device is not being recognised because I have added a second hard drive, reinstalled Xp on it, but old hard drive is still set to master, new hdd set to slave. Also when I open up case to change anything, after closing again, computer won't boot, just beeps. Am I doing something wrong each time I open case?
  • 801 Answers
Are you booting in from one of 2 hard drives at start-up .. ie. do you have a dual-boot system?
If your sound works fine when using the original hard drive but not when you boot from the slave, then it sounds like a driver problem -in the slave. You'll need to download the sound drivers for XP/Slave.
I can't think of any reason why your computer should beep after you have opened and closed the case. I don't think it is anything to do with the case. It's more likely that there's a bad connection or fault (maybe you have the slave and master on the wrong cable) - or badly fitted RAM.
Count the error beeps - there is a pattern of long and short beeps. You can find a list of their meanings here:
http://www.pcstats.com/articleview.cfm?articleID=1223
Though having said that, I would hazard a guess that you've got the master/slave configuration wrong. If you have both hard drives on one cable (ide) the MASTER drive should be at the end of the cable.
Remember there's a primary master (c) and a secondary master - your dvd drive. A 2nd hard drive would be set up to be the primary SLAVE. You cannot have 2 'master' drives on the same cable or bus. That would cause an error beep ...
Posted on Nov 29, 2013
3 Suggested Answers
SkullyFox
  • 93 Answers
SOURCE: Is the 2400 Toast ???
sounds like HDD and Cd-Rom are jumpered wrong (If on a PATA interface cable), make sure HDD is set to master, and cd-rom set to slave, alot of the early socket 775 board (mainly abit boards) initialised a few of its devices, shut down, and then started up again to initialise the rest.. its just the bios version they are released with, if the HDD and CD rom are on SATA, make sure the SATA inteerface is not set to RAID in the bios, if it is change it to IDE or ENHANCED, in earlier boards SATA was only provided on baord for the purpose of RAID, and simply a single HDD and CD-ROM will not work. failing all this, try changing your interface cables, i cant count the amount of times i spent an hour on a computer, and realised it was only a crook cable.. hope this helps
Posted on Dec 06, 2007
SOURCE: Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
Posted on May 23, 2012
Testimonial: "While my solution was sort of self discovered, another voice in my head helped me think harder. I appreciated the efforts very much."
May 23, 2012 | HP Omni Computers & Internet
I recently purchased bose multimedia speakers. I can plug the iPhone into the control and the sound is phenomenal. When I plug the USB into my laptop (HP6535b) the speakers install, but the sound is...
xp was never designed to do that ever. my guess... and is true in vast cases with XP , XP is DEAD, as will be getting new drivers for new devices, see?
When I plug the USB what does that mean.
all i can tell as would HP, take that USB thing above
go the the makers web site, see that software, there,
do they have XP software, NO.
i bet they do not support XP
not only that all said was,.
what does that mean>/ its non specific so is useless. input
the only word there good id BOSE(tm)
they make lots of things, most things do not run on any XP
unless real lucky,
my guesss is the BOSE(tm) has its own sound chip
and needs its own SOUND chip driver to work
and if even you had that chip driver,
XP would get real confused having 2 sound chips in one PC
try this , go to DM , device manager,
and turn off the normal sound chip from HP.
on windows 10 we click the task bar speaker and kill the onboard sound chip that way, letting head phones USB work.
or USB external devices that have, 2nd chip.
see? running 2 chips at same time (sound) is never going to work
like having 2 TV's playing same time, chaos.
Apr 27, 2017 | HP Computers & Internet
Added sound forge 6.0 to our new computer with windows 7 and it is not letting us access the program.
Hi m Otto ,
Apparently , the software is not built to run under Windows 7 . Try installing it on an XP computer or install a Virtual XP version with WMWarePlayer on your system to test the results .
Best regards ,
fanaudi .
Sep 27, 2011 | Sonic Foundry Sound Forge 6.0 for PC
I am trying to reinstall windows xp prof but i keep getting the blue screen and the system keeps shutting down, i have tried a different hard drive but get the same error.
unplug all devices except the hard drive and 1 cd/dvd rom drive. disable the audio device and any other unnecessary devices within the BIOS and remove all pci cards. remove all but 1 ram stick, and try using different ram sticks, one at a time, while trying to boot. if it boots, with 1 ram stick, 1 hard drive and 1 dvd/cd drive then try adding/reenabling the other devices one at a time, until you find the device that keeps it from booting.
if your pc wont load with just a hard drive, cd rom and 1 stick of ram, then it is prolly trashed. if removing/disabling one of the other devices (such as the sound card or the modem card) allows it to boot, then you have found what needs replaced.
Nov 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Problem is (the dist structure is corrupted and unreadable). please help
Hi, looks like you will need to format your hard drive and reinstall windows. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 01, 2010 | Computers & Internet
Need to factor reset,|NOT REBOOT, for acer aspire 3630 windows xp
Hi and welcome to Fixya..
Reinstalling Windows XP on an Acer Aspire 3000 is fairly straightforward. You may need to reinstall Windows XP due to hardware failure, a virus infection, major hardware changes or a hard drive upgrade. Whatever the reason, you can do the reinstall yourself at home. The reinstall will take anywhere from 1 1/2 to 3 hours, depending on the size of your hard drive. Be aware that reinstalling Windows XP will format your hard drive, getting rid of all data on, so you'll want to back it all up on a media device.
  • Step 1
Back up all data on your computer before reinstalling.
  • Step 2 Insert the Windows XP disk and restart your computer.
  • Step 3 Press any key when prompted to begin running the disk.
  • Step 4 Press F8 to agree to the terms of service.
  • Step 5 Choose the partition you want to reinstall Windows XP on. This is usually "C:" for most users.
  • Step 6 Choose the type of format. You can choose either "Quick" or "Full" for NTFS systems. A quick format only takes a few minutes less than the full format.
  • Step 7 Wait for the format to complete. The Windows XP installation wizard will begin. You will be asked to choose your time zone, computer name, and to input any network information. Otherwise, the reinstall will run by itself.
  • I hope this helps
    Oct 15, 2009 | Acer Computers & Internet
    Computer sees drive as Generic USB Device
    Hi Brian, It certainly sounds like either your drive enclosure or the drive itself has some failed circuitry. You can try moving the drive into a new enclosure, if you're not sure how, take it to a local computer shop and have them transfer it into a new enclosure and test it for you. If it works in the new enclosure, you're done! If not reply back here by adding a comment with your country and city and I'll pass along a recommendation for somewhere to send the drive for data recovery. Chris
    Jun 05, 2009 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
    Hi I have a WD1200BEVS hard drive making a musical two tone buzz. Any chance for repair?
    If you can boot up your computer, I would back up your data before your hard drives fail completely. It is unusal to have both hard drives go at the same time.
    Mere mortals such as me and you cannot repair hard drives, basically buy new ones to replace the faulty drives.
    To reinstall Windows on your new hard drive, you will need the Windows XP or Vista CD install disk plus all the device drivers for all the installed devices in your computer (eg. video, audio, LAN etc.) and install those that Windows could not install.
    Make sure when you download these device drivers that you select the ones that is specific to the version of the Windows operating system you installing.
    Dec 06, 2008 | Computers & Internet
    Hi mate...
    Hi there. It sounds like the XP you have installed doesn't have the correct/updated driver for your sound card. Try installing the most current Sound driver from the manufacturer's website. It would also be a very good idea to download XP Service Pack 3 from Microsoft, as this will have added support and drivers in the database.
    Let me know if it works
    Thank you
    Tim
    Dec 05, 2008 | Microsoft Windows XP Professional With...
    No sound after reinstall windows xp sp3.
    you cannot downgrade from Vista to Xp unless you format your hard drive or install xp on another partition check your device manager for yellow marks on sound devices and update your sound drivers
    Nov 08, 2008 | Lenovo Computers & Internet
    Computers & Internet Logo
    70 people viewed this question
    Top Packard Bell Computers & Internet Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Tony
    Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
