Question about Samsung B1245 Front Load Washer
Ue code just keep comeing up with ue 7 mins to the end of the washer
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
UE displayed on panel westinghouse 708 washing machine near end of cycle shows 6 mins left on spin then shows UE, cannot go into normal cycle.
I WOULD TRY TO LOOK AT THE DRAIN PUMP ASSEMBLY ON THE UNIT.... IT IS EITHER STOPPED UP OR NOT PUMPING FAST ENOUGH OUT DUE TO DEBRI IN THE PUMP AREA... GAIN ACCESS TO THE DRAIN PUMP AREA AND REMOVE HOSES AND LOOK INSIDE AREA.
the code data base for this is saying ue = drain failure... hope this helps you out
Jan 06, 2011 | Westinghouse Washing Machines
Error code "UE" clothes have
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
Code UA or UE keeps on comin up on my lg
Hello
Hold down the pause and cancel buttons for 5 sec.
Or unplug unit for a min and plug back in to reset.
May 04, 2010 | LG Washing Machines
Keep getting UE code
You have a problem with the ball switch sensor in the back of the unit.  I have seen this problem where the delivery people actually dented the back panel so badly that the ball sensor was jammed up against the tub and kept going into UE error code.  Check to make sure that there is no large dents in the back of the unit.  If everything looks normal, then you will need to call and qualified LG technician to service this problem.
Mar 23, 2008 | LG WM1815CS Front Load Washer
Samsung B1245 Front Load Washer Logo
23 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
