Question about Possini Euro Design Dryers
Possini Euro LED light show flushmount ceiling fixture missing LEDs (2 light blue external row, cannot find replacement, lamp is beautiful but dysfunctional)
LEDs fell from the fixture and I am unable to identify and find a replacement. Is it possible to locate the manufacturer? I made multiple searches and so far I was unsuccessful. Thanks!
  • 2,113 Answers
If you go to an electronics supply you can match most leds, maybe no perfectly but similar in brightness and pin size.
Posted on Nov 29, 2013
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
SOURCE: installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Posted on Aug 21, 2009
heatman101
  • 43501 Answers
SOURCE: In changing out an incandescent light bulb in a
Many times with very old wiring the wire can break inside the coating and not be visible. To check for sure what has happened you will need an electric tester. You will need to check for 120 volts acros the two wires with the switch on. If there is no power, then check at the switch. If there is power there then the wire is broken.
Replacement of the old wires in an old house is very difficult and you will probably want to hire a professional to do that.
Heatman101
Posted on Mar 01, 2010
  • 202 Answers
SOURCE: where does the blue connect at house wiring black
White is neutral. Black wire is hot. The blue wire that comes from the fan/light fixture is for the fan, the black is for the light. You can connect the blue to the black. The only thing that when you turn the fan the light will come on at the same time, unless you have a different switch
Posted on Mar 16, 2010
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
How to retrofit fluorescent tube with led tube lights
Note:
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit www.ledclan.com
May 21, 2014 | Acclaim PIXEL TUBE w/ 15 RGB LEDs
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Extra blue wire what is it for
48" light fixtures come in single lamp, two lamps, and four lamps. The ballast must match the supply voltage and the amount of lamps the fixture has.
Dec 23, 2010 | Lithonia Lighting White Finish 48" Wide...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
Remove exixting fan
Should have screws close to the ceiling on cover, then if it's a ball and socket you lift up and out through the cutout on the socket bracket, or a flushmount you find the screw that attaches to the bracket and lower down. then just take off wire nuts and install new fixture. Hope this helps.
Jan 23, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Dryers Logo
Top Possini Euro Design Dryers Experts
Dan Webster
Dan Webster
Are you a Possini Euro Design Dryer Expert? Answer questions, earn points and help others
