Bush freeview recorder bu11fvrsd50/x no sound
Connected via scart good picture but no sound mute no turned on
Benimur
  • 6966 Answers
SOURCE: Connecting up CRT TV, VCR, DVDR and digital box
With the indulgence of Mrvica, it would seem you posted the same concern twice. Here is a link to your other post with responses from xx and this responder.
Hope this be of help/idea. Pls post again should you need additional information.
Good luck and kind regards.
Posted on Jan 31, 2008
Palmbeach
  • 185 Answers
SOURCE: Total lock up
The reason your dvd recorder keeps self checking is because there is a faulty regulator on the power board.
I have listed full instructions on how to fix this, but you will need to be able to use a soldering iron and exercise care. Alternatively you may be able to pass the instructions to someone who can repair it for you.
Do not listen to anyone telling you the laser is faulty, DVD drive unit is kaput, it requires firmware, software or any other useless upgrade, or that Panasonic will do it for the price of a small car! It is easy to fix..
I won't repeat the instructions here but if you look at my profile and search my DMR E55 solutions you will find it.
The regulator gets very hot during normal operation and it will eventually fail on all DMR E55s after a couple of years or so.
It was probably on its last legs and when you put the lead back in, you probably didn't disconnect the plug from your power socket and this caused a power surge which has finally killed it.
If you know what you're doing it's an easy fix.
It definitely does not need a software reboot.
I would be reluctant to use it again until it has been fixed because if the regulator overheats further, it could short circuit and cause other components to fail which would make the repair more difficult.
To check to see if there is a disc inside, unplug the unit from the mains, remove the two large silver screws, one on each side, then the three black screws on the back of the lid which can then be easily removed.
Next, remove the four small phillips screws that hold the top cover on the dvd drive. This is a large black plastic cover in the middle of the unit. The cover can then be taken off and disc removed if there is one inside. DO NOT TOUCH ANYTHING ELSE. replace the cover and screws, then repair the unit.
Posted on Feb 29, 2008
  • 4234 Answers
SOURCE: I am connecting a Technika
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Posted on Mar 18, 2008
Mark_Webber
  • 472 Answers
SOURCE: Can't record Freeview
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Posted on Apr 12, 2008
RFICKES
  • 51 Answers
SOURCE: unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
We want to connect our Sanyo VHR-795E to a recently purchased LG freeview TV to record programs. Our best efforts so far have resulted in recorded picture but no sound in playback mode. We have tried...
Some TV's have different settings for outputs at scart sockets. Read the manual on the TV to see if it mentions what the scart(s) sockets output.
However I think you might find it better to connect your VCR to a seperate Freeview box, that way you can watch a different channel to the one you are recording. Box's are cheap at the moment you can get one for around £10 on E-Buyer.Com.
Aug 23, 2011 | Sanyo Televison & Video
I have a Digilogic VCR/DVD player model DVDVCR1 connected to a tv with freeview already installed. But I am unable to record digital programmes from the TV.Will I have to bin my VCR/DVD player and replace...
I'm assuming you mean the recorder doesn't have freeview built in?
Then all you have to do is to get a cheap freeview box and just have it connected to your vcr via a scart lead. If the VCR has two scarts connect the one to the tv for playback and use the other for the box. If it has only one scart, then get a switcher box, there's some good ones on Amazon, that will allow you to select the different sockets and record from.
Nov 11, 2009 | Televison & Video
Bush BTU160DTR No Picture
Check the scart lead is fully in on the box and the tv
Sep 09, 2009 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Hope that helps =)
Apr 12, 2008 | Philips VR550 VHS VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
