Question about Dirt Devil Vision Cyclonic Canister Vacuum, SD40025
Vacuum won't start
It quit while using it. Now it won't start. Only second time in use.
    Problem Solver:
  • 31 Answers
Check the plug fuse (for uk standards) or
broken cable
Posted on Nov 29, 2013
  • Clinton McGrath
    Clinton McGrath Apr 24, 2014
    how do you find the plug fuse
  • Clinton McGrath
    Clinton McGrath Nov 06, 2015
    Found the 15 or 20amp ceramic fuse inside vacuum replaced it and got it working.
    Thanks
I have a shark v6 that won&;t run all the time. It starts and stops when you are trying to use it.
Is this a battery powered vacuum? If so the battery is failing is my guess.
Jan 25, 2017 | Shark Vacuums
Vacuum power bar
By the power bar do you mean the roller at the front of the vacuum underneath, if so then what as more then likely happened is the belt has stretched and broke due to the bed sheet putting so much strain on the belt. You will need to replace this by getting a new belt for your make and model and switching off the vacuum and pulling the plug out of the wall first and then undoing all the screws which on most vacuums are underneath the head of the vac. once all the screws are taken out and the top as been taken off lift the roller out put the belt onto the spindle at the back and then place it around the roller and then pull towards the front of the vacuum to hook it back into place. This will be quite hard but it will do it and once on with your fingers push the roller around and few times to let it seat the belt into place and then build it all back up and start using it again. If you cant find out how to undo the head of the vacuum message me and I will try and let you know where each screw is to take out before you can replace the old belt with the new
Feb 02, 2014 | Eureka Vacuums
Motor quit
Does it come back on right away or do you have to wait a while. Could be faulty thermal sensor.
Nov 03, 2013 | Dirt Devil "I" Upright Vacuum - Red...
The paper filter on the Shop Vac locking ring won't stay on, how do I fix this?
It has to be pushed all the way on to where the plastic is solid. It's usually quite hard.
Apr 13, 2013 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Dirt Devil Vision Cyclonic Canister Vacuum, SD40025 Logo
66 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
