I would like to run a coleman rv roof air conditioner Mod # 6727-736 on the bench before installing on the Rv. It is a used unit. The plugin has 6 wires. I wont to see if the compressor is still ok. gerhard
    Guru:
  • 588 Answers
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO
www.rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on May 12, 2009
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Need the schematics for 6721A or 6723A Coleman RV air conditioner
Check this link but look for model number on base of roof unit. Roof unit will be one number and whatever ceiling assembly will determine what to do with wiring.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 19, 2011 | Dometic Rooftop RV Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
GO TO rvcomfort.com
Jul 27, 2010 | Coleman Mach III Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Jul 20, 2009 | Heating & Cooling
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
GO TO rvcomfort.com
Apr 20, 2009 | Coleman Heating & Cooling
Coleman roof a/c units compressor not coming on
GO TO
www.rvcomfort.com
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
