Question about Home
How do i get
Rid of squirrels in the attic after I stop the way they come in
Moth balls will get rid of squirrels will find one way or another it may be in your house
Posted on Dec 02, 2013
What are signs of squirrel damage in home attic?
Usually torn out insulation and stool droppings.they like to build nests out of insulation fibers.any disturbed areas check for droppings and nut shells.
Mar 25, 2015 | Heating & Cooling
Facts about gray squirrels
Thay are nasty , don't get bitten by one thay dont let go and thay can jump high and far ps get your self some rat traps and put them into the loft with some peanut butter , be careful thay haven't chewed through some of the wiring and good luck colin
Jul 19, 2014 | Roofing
Chipmunks in house are chewing the wiring
Hello Nail4, Try placing mothballs in the attic.
Mar 12, 2014 | Black & Decker Electronic Pest Repeller...
Squeal sound from attic unit
sounds like bearing issue or squirrel cage rubbing on fan housing.
Jan 18, 2014 | Goodman Heating & Cooling
The AC unit up in the attic became very noisy few days ago. My husband went up the attic and he said the noise is comming from the fan it shakes very bad once the ac is on. What do you think that is the...
I would check the bearing on the fan motor .You can try to move blower back and forth and if it moves more than about 1/8 inch then you may need to replace the motor. Check the mounting bolts that hold squirrel cage in placeAlso check the bolt or set screw that holds blower to motor shaft to make sure it is not letting the blower move when the motor is running. I would clean the fan and motor as well as you can and oil motor if it has oil ports. Hope this helps you. Thanks
Jun 20, 2011 | Heating & Cooling
When the central air turns on it is very loud. I assume its the fan or whatever is in the attic. it sounds like a really loud regular window air conditioner on high coming through all of the vents. Is this...
No. This can be caused my a dirty squirrel cage on the blower motor which is found in your air handler in the attic. Probably needs to be pulled out and cleaned. This noise is caused by the blower wheel out of blanace.
Jun 25, 2010 | Heating & Cooling
Sounds like a squirrel inside water heater
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
May 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Air conditioner/heater does not work. It hums but no air comes out.
Hard to say exactly, but it sounds like you may have debris in the squirrel cage for the blower and has stopped it or the squirrel cage came off and the motor is running. Is air coming out anywhere?
Dec 05, 2009 | 1992 Mercury Topaz
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
Home Logo
555 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
