Question about Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator
Frost on back panel and not making ice also does not seem very cold.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
There is a problem with your automatic defrost system it could be one of three components
Posted on Dec 01, 2013
Sea Breeze
  • 4655 Answers
SOURCE: Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Posted on Oct 24, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
  • 3422 Answers
SOURCE: frost in top freezer - water leaking in refrigerator - ice maker not working
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature IN THE FREEZER! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
Posted on Oct 08, 2008
woodchuck789
  • 4070 Answers
SOURCE: The fans come one but both sides are not cold
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Apr 27, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Why are only drawers in fridge cold & not making ice?
    Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
    Posted on Aug 14, 2012
    GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
    Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
    Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
    Freezer is not cold enough to make ice and all the contents are dethawing. Fridge is also not cold enough to keep things as cool as they should be
    Seems like a defrost problem. Pull back panel and check frost pattern, if completely frosted,Turn the defrost timer (behind the kick panel in front, or mounted on the back panel) till the fridge goes into defrost. If defrost heater now gets red, replace the defrost timer, if not remove the defrost thermostat clipped to the evaporator coil, and check for continuity while still cold.
    Jul 07, 2011 | Kenmore 50522 / 50524 Side by Side...
    My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
    your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
    Aug 05, 2010 | Whirlpool Refrigerators
    Last month I had a problem with my Kenmore side-by-side #596-52673200. My refrigerator would not get cold. I followed the suggestions of one of your experts and remove the ice and frost behind the panel in...
    HELLO,
    The non cooling is brought by the Expanded and Rapidly cooling air which keeps it cool is being blocked by the ice, and simultaneously being condensed by the temperature difference... The ice blocks its path and forms frost...but there is obviously air coming in contact with it...The problem is typically air is leaking in the fridge somewhere, make sure doors shut tight after cleaning the frost in the back panel...this should do it...:)
    Sep 08, 2009 | Refrigerators
    Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
    Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
    Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Frost on back of bottom freezer of a 3 year old kenmore
    how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
    May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
    BEKO Frost free freezer not as cold as it should be!
    Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
    Apr 12, 2009 | Freezers
    Fridge stopped getting cold
    Check for frost on the back wall of the freezer section. If there is frost there your problem is defrost related to a timer or defrost heaters. I say this because you indicated it still makes ice cubes which indicates it is still working to some degree. Check the condenser for cleanliness and clean if necessary. Under the refrigerator front behind toe plate and /or in back behind removable panel.
    May 19, 2008 | GE Refrigerators
    Bottom not cold enough
    did you remove the back freezer panel ? if not need to
    is there a large anmount of frost on the coil behind the panel?
    if there is thaw the coil with a hair dryer
    if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
    if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
    May 17, 2008 | Kenmore 21.7 cu. ft. Top Mount...
    Frig not cold but freezer is ice maker not making much ice either
    Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
    Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
    Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator Logo
    50 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
