Trans getting hot in 2001 dogde 1500 ram pickup
5 Suggested Answers
  • 9 Answers
SOURCE: 2004 dodge ram 1500 3.9 auto trans problem
Check fluid level first. See if fluid smells "burnt". The signs are the tranny is dying. Don't go far in this vehicle until you've taken it to a shop you trust. They will pull the drain pan and inspect. Next sign of death will be a whining in the transmission as the suction strainer for the pump becomes clogged with the clutch material. Good Luck.
Posted on Dec 23, 2008
  • 46 Answers
SOURCE: will trans from a 98
no van is front wheel drive pickup rear wheel drive , they are different transmission's.
Posted on Oct 27, 2010
  • 51 Answers
SOURCE: what is firing order in dogde ram 1500 1/2 ton pickup 5.9 liter v8 2001
1-8-4-3-6-5-7-2. I googled your question and found the firing order there hope this helps. I do know on some engines the firing order is on the engine block of that motor.
Posted on Jun 12, 2012
  • 4134 Answers
SOURCE: Will the dash from a 1997 dogde ram 1500 4x4 fit a
Highly unlikely. Car/truck manufacturers don't apply the old VW beetle philosophy that reuse is cheaper; they redesign every year. Even if it would FIT, the wiring harness is bound to be significantly different between the two model years so most things would not connect up correctly.
Posted on Dec 18, 2013
Will the dash from a 1997 dogde ram 1500 4x4 fit a 2000 dogde ram 1500 4x4 sport?
Dec 18, 2013 | Cars & Trucks
What is firing order in dogde ram 1500 1/2 ton pickup 5.9 liter v8 2001
Jun 12, 2012 | Dodge Cars & Trucks
2001 Dodge pickup 1500 5.2 liter. Some times it will kick and buck while shifting from 1 to second in the automatic trans and sometimes from second to 3rd. Back off on the accelator and it somothes out if...
Hi, Have you checked the thouttle sensor? Also replace the gas filter it maybe clogged and thats why it bucks. It's not getting enough gas for it to run correctly.
Jun 27, 2011 | 2001 Dodge Ram 1500 Truck 2WD
2001 dodge 1500 pickup. The air conditioning
It sounds like a low charge. It could be a clogged expansion device also. It has a higher probability of being a low or contaminated charge.
Jun 23, 2010 | 2001 Dodge Ram 1500 Truck 2WD
I need the Belt Routing Diagram for a 2001 Dodge Ram 1500 V6. There is no diagram anywhere under the hood.
Click on the following free direct Link. It has several Diagrams including the correct Serpentine Diagram for your 2001 Dodge Ram 1500 2WD Pickup with the 3.9L V6 Engine with the various Engine Options (AC/No AC, etc.).
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/dodge/model/pickup/2001_dodge_pickup_drive_belt_routing_diagram.htm
Mar 06, 2010 | 2001 Dodge Ram 1500 Truck 2WD
My 97 dogde ram dose not like to shift into 3rd gear unless i take my foot off the gas. i was told I needed to change both solenoids. can I do this myself? Is this the problem?
Your description does not sound like solenoid issue.
I need to know what your vehicle uses for throttle position indication to the trans. IS there a rod from throttle body area to the trans? If so, adjust that to have slightly less effect.
If not, look for vacuum leaks or cracked hoses to trans...
Doc
Sep 19, 2009 | 1998 Dodge Ram 1500 4WD
Heater not working on 2001 dodge pickup
its very common for the recirc door to break off its hinge and lay over the blower motor blocking the air flow
Jan 08, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Dec 23, 2008 | 2004 Dodge Ram 2500
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
