Question about Acer TravelMate 2303LCi Notebook
When laptop is plugged in pointer dosnt work but when unplugged it works
L7750 laptop- built in pointer stopped working, properties says most recent driver installed and is working properly.
remove anything you have attached to your laptop and unplug the power and battery. Hold the power down for 30 sec. Put your battery back in and plug in the power cable. At the Toshiba splash screen hit F2 to enter the bios. Press F9 to restore defaults. Then press F10 to save and exit. this should fix your problem.
Oct 30, 2013 | Toshiba Computers & Internet
Mousepad only turn on or off dont work
Firt shut down, unplug, remove battery, plug in, reboot. Does it work? If not install the touchpad driver and reboot. You can find the drivers here, select your OS : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=1817074
Dec 18, 2012 | HP Pavilion dv2000t Notebook
There is no pointer and don't know how to get it back, can get into mouse options but can't do anything without the pointer
Shut down, unplug from AC, remove battery, plug into AC reboot, Have you tried a USB mouse?
Dec 13, 2012 | Computers & Internet
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
Had a storm lightening struck something lights went out came back on but router dosnt have solid green light just flashing orange light modem dosnt see the router but if i plug in to laptop bypassing...
It appears lightening has damaged your router. Do you have a surge protected powerboard and do you plug all your computer equipment into this powerboard?
If you do not have a surge protection board, I suggest you install one to protect your equipment.
Aug 05, 2010 | Belkin (F5D7230-4) Router (587009)
My laptop is not working. When I press power button, only blank screen appears. But the processors' fan is functioning
Hi. I would suggest to power drain or power cycling your laptop, by removing the battery and unpluging the ac adapter and press and hold the power button for 20 sec while the battery and ac is out then plug it all back then turn on your computer. If this dosnt work try reseating the RAMS or memory of your laptop. If does Troubleshooting step doesnt fix your issue then maybe this one is already a LCD hardware issue. Also try calling there tech support hotline at 800-426-7378 if your laptop still under warranty and they would replace the LCD without any charge. Hope this Helps.
Jun 08, 2010 | IBM ThinkPad T40 2373 Notebook
Mouse pointer keeps wavering in the screen. Im not
try to look for the proper signal, try to click the button on the mouse, or try to unplug it and plug it again.hope it work.
Sep 30, 2009 | Samsung Pleomax SCM-9000 Mouse
My microphone dosnt pick up any sound
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Aug 24, 2009 | Logitech Internet Chat Consumer Headset
LAP TOP WILL NOT WORK WHEN PLUGGGED INTO DOCK. tHE POINTER FREEZES WITH THE REMOTE AND ALL FUNCTIONS TO LAPTOP USULLY FREEZE. MY 1.44 MEG FLOOOPY AND MY POINTER WILL WORKSOMETIMES WORK UT iF i UNPLUGGED...
unplug everything from the docking station, and press and hold the power button for about 15 seconds. Afterwards, plug in only the power and the monitor to the docking station and dock the laptop (make sure the laptop is turned off before docking and turn on after docking). If you still have issues it could still be hardware or software at this point. If you do not have issues, plug in one thing at a time to the docking station (mouse, keyboard, ect.) and restart the laptop each time until the problem starts again. this is how you will know if a device in the DS is causing the issue. if your monitor is vga (port on back of docking station where monitor is plugged into is blue) try plugging it directly into the laptop. also try plugging in the keyboard and mouse directly into the laptop (if they are usb) and anything else you may have plugged into the DS. This will be a better way of testing your devices. If all devices work fine, i would say that it could be more of a hardware issue with your DS.
Jul 22, 2009 | Dell Latitude C600 Notebook
Laptop touchpad is left-clicking when it is touched.
hi,
Please reduce the touchpad sensitivity. that shld take care of teh issue.
inu
Dec 09, 2008 | Gateway MT3705 Notebook
Acer TravelMate 2303LCi Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
