Question about Honeywell Programmable Thermostat Heater
My honeywell thermostat model rth221b1000 worked fine for AC but now when using heat, the heat will not cut off on it's own, I have to do it manually. Any idea what might be wrong?
New thermostat worked fine in summer with AC, but now when using heat, it will not cut off automatically. I have to do it manually. I do have a blue wire that is not connected to anything but I read it was not used for this model.
    Habit-Forming:
  • 188 Answers
You have 5 wires hooked up? What color is on the Y terminal? It is set on auto, heat and a temp low enough for the furnace to reach?
Posted on Nov 29, 2013
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
My thermostat isnt kicking on my furnace. even if i use the arrow to increase it, still no heat and it isnt kicking on the furnace. even tried changeing the batteries. sometimes it will say,"return" n
Recheck that the thermostat is wired correctly. If so,switch it to fan on and see if the fan comes on if the fan does not come more then there is definitely an issue with the furnace and not the thermostat.
Feb 15, 2015 | Honeywell RTH221B1000-OB Open Box Basic...
I installed my honeywell rth221b1000 this summer and got it to work with the a/c. When I switched it to heat it does not heat. The heater seems to come on but it does not heat and the fan does not run. I...
If when you turn the heat on you hear the furnace fan start up (exhaust fan) then the problem is NOT the Thermostat....need some more info on the furnace...the Wiring in the thermostat should include a Jumper wire between RH & RC if you have 4 wires and no jumper required if you have 5 wires
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
How do i program my thermostat rth221b1000
go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
My heat wont turn off
if you have an emergency heat position we will assume you've got a heat pump. If you do not have a heat pump you have the wrong thermostat for your application. Need model of this thermostat, wire colors, termiation points (what terminal designator they are connected to), and if you have it where they were and the model of the last thermostat that worked correctly
Nov 17, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
83 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
