Used to see probe flash on control screen when probe plugged in. Nothing happens when on conv bake mode or any other setting. How do I test the probe, the harness wiring and control panel? All other oven functions work.
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
SOURCE: GE Profile JT952 Double Wall Oven
sounds like the heater element needs replacing. But before replacing it or buying one would be a good idea to check your power point (wall socket) to make sure it is okay. Then check the oven wires to make sure there are no burnt or broken wires. Check for fuses that might have blown - some ovens do have fuses. After checking all of these you will need to check to see if you have power getting to the element. If not chances are you have a faulty switch. If you are getting power to the element chances are the element is faulty and will need replacing. Hope this helps.
Regards
Bryan
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
SOURCE: JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
SOURCE: GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
