Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
No heater fan with remote start and battery light on
Drains battery when running on remote start
  • 34 Answers
Short bad ground wire
Posted on Dec 02, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
When i put the heater on in the car while running it drains battery and after shutting the car off it won't start battery dead
This would be a fan issue in most cases because the heating is done by using the water system that gets hot from the motor and then is blown throughout the car to make it warm so the only electrical device getting used is the fan unless you are also using the AIR-CONDITIONER to heat the car which will drain a lot of power .
Nov 18, 2017 | Cars & Trucks
I have an Airworks ceiling fan/light with remote. Worked fine for years. Now battery is being drained very quick.. in a matter of a couple of weeks! Replaced battery but it drains in a couple of weeks
Stuck button, spill on remote causing power drain or most probably you got a batch of weak batteries. Try a different brand and make sure they are alakaline.
Aug 15, 2016 | Dryers
2003 Jimmy 4.3 Battery drained down every few days and had to be charged. Today the battery was dead. Replaced it.
check charging rate on new battery with engine running, should be 13.7 +.
if not, check alternator.
if alternator checks out, may be a drain somewhere, light on someplace, etc.
Oct 06, 2015 | GMC Jimmy Cars & Trucks
Heater fan motors
The most common issue is the fan relay is NG or a bad AC/ heater switch (if we are talking about the AC/heater fan.
Apr 17, 2014 | 2005 Chevrolet Impala
I have a 1994 f-150 pick up got a new battery & when i put the heat on it discharges & now truck won't.
You mean with the engine running? If the engine is running, the heater fan should be getting power from the alternator, not the battery. Does your battery light go off after engine is running? Or does the voltage gauge show normal charging when running?
If you can start the truck, have your charging system checked out. If it won't start now, have the battery charged up and try again. Then have the charging system checked. If it is good, your heater fan may have a short and drawing too much current, But a heater fan will run the battery down pretty quick, if the engine is not running.
Jan 06, 2013 | Cars & Trucks
Battery constantly dead, changed battery, alternator, tested starter, no bad fuses or lights staying on, disconnected amp and speakers, also have noticed issue in ignition, sometimes it starts when I turn...
If hot water is hitting you in the feet change your heater core under the dash it has a hole in it. Something wet could be your problem wet connections will drain a battery over night.
Feb 20, 2011 | Volkswagen Fox Cars & Trucks
The battery, which is new drains and does not charge during each use of the vehicle.
you need to check the charging system with a multimeter ,start the vehicle and turn on the high beams and the heater fan to high,and put four ways on,now check what voltage reading you have at the battery post,it should not even be lower than 12.5 volts.
Jan 26, 2010 | 1999 GMC Sierra
Battery drain. alternator and battery ok. 30 amp fuse in front location shows arc. can't identify what fuse controls. is there a schematic which will show these fuses and their. purpose? ie coutesy lights,...
my battery drain indicator lamp is lit on my 2000 Toyota Camary. i checked the battery and have 12.5 volts when not running and 14.5 volts when running with lights & heater on. since all my other gauges are working ok i'm not sure if its a fuse or what fuse. can you help. altenator shows 14.5 volts when running.
Oct 26, 2009 | 2001 Toyota Avalon
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
85 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
