Question about Ovens
Whirlpool AKZ161 Oven made a bang noise when cooking and tripped the circuit. When' reset the oven has no power. Is there an internal fuse I can check or is it the element?
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
revamos
  • 16 Answers
SOURCE: Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
Posted on Apr 19, 2008
  • 1462 Answers
SOURCE: ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Oven cooked a meal then no power
Check your junction box circuit breaker for issues. This should be on a 220 outlet. Find out if your model has an internal safety switch. If you trouble shoot all areas, then time to call a repair person.
Mar 03, 2014 | DeLonghi Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
No power is there a reset button
There is no reset button on this model.
Check to make sure your circuit breaker is not tripped in the home.
There are internal safety thermal devises that could have tripped or the main control board gone out.
Apr 24, 2010 | Whirlpool RBS275PD Electric Single Oven
Hotpoint oven bu72 gave out loud bang when cooking dinner and blew trip, reset trip and whilst top oven and grill work we cannot get any heat from main bottom oven
Sounds like the element has internally shorted to earth and will have to be replaced by a qualified Techo.
While this may have caused a fright...think how lucky you are that the Safety Switch was invented as a fail safe lifesaver!
Oct 25, 2009 | Ovens
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Oven cut off in the middle of cooking
From what you say you seem to have no power to the oven, Check for blown fuse or tripped circuit breaker, check connections in plug. do you have a reset button anywhere, check your user manual.
Dec 10, 2008 | Kenmore 47783 Electric Single Oven
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
