Question about Hobart SR24-H Built-in Dishwasher
Drain valve issues - Hobart SR24-H Built-in Dishwasher
Fisher and Paykel EcoSmart GWL15 won't drain at the end of it's cycle. I put it in diagnostic mode and the got it to drain that way. I ran another cycle and it wouldn't drain on it's own again. Put it back...
Hello Robert. If you have heard any kind of squeaking or squealing or rattling while the pump was running, replace the pump. You mention a humming noise. Also a sign to replace the pump. When FP pumps fail, they will not spin at the correct speed and that is why when you run it in diag mode you can pump out the water as it runs until you stop it, but will not drain in a normal cycle. Be VERY careful when you replace the pump. Make sure you get no water in the new pump windings when replacing the pump or you will WILL take out the machine controller. Pump p/n is 479595
Apr 09, 2014 | Fisher Paykel EcoSmart GWL15
Washing machine drain problem
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
Mar 09, 2008 | Washing Machines
E11 code on electrolux dishwasher
You are experiencing a drain valve issue - Main Control Board timed out before receiving status of drain valve. Check wiring between Main Control Board and drain valve. If correct, replace drain valve. If error still exist, replace Main Control Board.
Aug 16, 2012 | Electrolux Dishwashers
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
I have a Richmond model 8MV50-2B. I'm having issues draining the tank to check the electrodes. Normally, on a water heater there is a shutoff down near where you attach the garden hose to drain the...
Problem is not clear.
Is water heater clogged and not draining?
What kind of shut off is normally located down near drain valve on electric water heater?
If you have gas heater, you can normally just rotate knob to pilot to shut off burner.
If you are draining electric water heater, normally you turn off circuit breaker, attach garden hose to drain valve, open drain valve by turning counterclockwise, open TP valve or open bathtub faucet, and then water drains out.
Open following links for illustrations.
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Aug 13, 2011 | Water Heaters
My MIele G682 SC is draining slowly. Everything is working fine in the beginning cycle but by mid cycle the intake/drain warning light comes on and the machine shuts down I suspect thers is something...
Hi dear.That sounds like,your machine has water intake restricted.Here is the link you can download manual for G692-G892 & follow the "problem solving guide - cleaning & care sections" go to page 50 & progress the explanations. http://www.miele.co.uk/Resources/OperatingInstructions/G%20692%20and%20G%20892%20Plus.pdf
I hope that helps.Thanks.
Aug 29, 2010 | Miele G892SC SS Dishwasher
Water heater overflowing
Is it coming out the releif valve on the side or top. If so it can be replaced, just shut water,power and drain down and replace.It is a standard 3/4" thread and not to costly.
Now it is the drain valve at the bottom turn everything off and drain it down and replace the drain valve.
Check out these links below for pictures and details to help you with this issue.
This link is for Pressure relief valve testing and replacement.
http://www.water-heater-repair-guide.com/waterheaterreliefvalve.html
The link below has an in depth details of how to change a drain valve out.
http://www.water-heater-repair-guide.com/waterheaterdrainvalve.html
Jun 24, 2010 | Water Heaters
Dishwasher model favorit 4950 i water does not drain away, however lights flash so does not appear to be an electic issue
This is difficult because it can be so many situations that do not allow the unit to drain. Clogged drain hose especially at the disposer connection, or kinked hose, or the drain pump (if seperate from wash pump, or drain selonoid valve coil or stuck valve flapper, or electrical connection leading to the valve or leading to the drain pump motor, or the timer control that has failed (within itself) and never sends power to the drain items, or can be debri or a piece of broken glass that lodged in the pump passage. Goodluck,Macgivor
Jan 27, 2010 | Washing Machines
My GE dishwasher drains fine after wash cycles. However, After rinsing, about 2 inches of water is left in the tub. The drain runs for 30-35 seconds at the end of each wash cycle, but only 4-5 seconds...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 12, 2010 | Dishwashers
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hobart SR24-H Built-in Dishwasher Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
