Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
110 sony flat tv was plugged in 220
I accidentally plugged my Sony Flat TV on a 220VAC which is suppossedly on a 110VAC and something inside burst out. I have already checked the fuse and replaced it with a new one but still my TV does not work. What part is still busted, appreciate so much your help and feedback... thanks in advance.
    Champion:
  • 252 Answers
Change the regulator of your tv and check also the resistor value 2.2 5 watts or lower value.
Posted on May 09, 2009
  • jose jeo patalinjug
    jose jeo patalinjug May 09, 2009
    change the regulator of your tv and check also the resistor value 2.2 5 watts or lower value.
When i repair my sony tv i accidentally touch any components and the tv totally dead.
You may have fried the electronics with a static discharge as you didn't earth yourself right before you started touching the electronic components inside
Dec 02, 2015 | Sony Televison & Video
Sony TV KDL-40EX720 is faulty!
From your video, it looks like a mainboard, Tcon or cable issue.
You can try to contact 40 diag LED EX720 Series Internet TV Sony to see if they have spare parts for this. Those three items above I would target as the main problems.
Feb 12, 2015 | Sony 40 BRAVIA KDL-40EX720 Full HD LED 3D...
Will a Sony Bravia LCD KLV 46S200A power 110-240 V work in America I have bought it in India
If voltage rating is marked as 110-220VAC, It should work in India. If it is marked, 110VAC only, you have to use a step-down transformer. Check it well, before connecting the set to AC Mains. Refer its user manual for more details, and make sure about this auto voltage range. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
I have sony KDL32CX520 model it happen to turn into blank scrren while watching tv but the sound works?whats the problem??
What do you mean by this blank screen. A screen with back light only? A screen without any back light [dark screen]? Provide more details please. If you wish to get details about these type of faults to Sony LCD TVs, check this link.
Feb 03, 2013 | Sony 32 inch KDL32CX520 Series Full HD...
Sabre 37in multisystem TV has blinking yellow light and won't turn on. Now in Europe, 220V. Should work fine.
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
Sep 15, 2011 | Sabre LCT371BKA LCD TV
I have a Sony Bravia 32" LCD tv...my query is that if the tv will be suitable in 110voltage plug or we should change it to 220 volt?
try to check first the voltage requirements at the back of your tv it is printed there, but most of the tv models specially the lcd it is auto volts.
Jul 10, 2011 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
We have a Sony Bravia 2 years old from USA (110 vault) and have now moved to Singapore (220 vault). Can we plug this tv in or do we need a transformer?
you would need a step-down transformer from 220 volts to 110 volts. Also you need to consider the Frequency as USA uses 110-115V 60Hz and many countries around the world use 220-240V 50Hz. In addition you need a physical wall plug adapter so you can plug the power cord into the wall. These are not very expensive but get the proper kind. Generally it is a good idea to buy a TV over there which is more compatible.
Apr 03, 2011 | Televison & Video
How to convert from 110 Volt power to a multivoltage or 220 Volts karcher pressure washer
Hi in the case of your pressure washer it would cost more to convert it than it would to replace the whole thing. The motor winding is currently 110 VAC and you would have to completly change out the motor with a 220VAC Motor. The power switch for 110VAC can probably be used for 220VAC.
There are things called (servo type) AVR's Automatic votlage reulators that you can buy to convert 220 VAC to 110VAC.
http://i194.photobucket.com/albums/z43/msgamboa0205/SiegAVR.jpg
You will just have to shop around locally. These are heavy and cost a bit to ship.
Probably not the options you wanted to hear but other than finiding a way to install a transformer inside your power washer that will handle the load of the motor and NOT melt the chassis of the power washer... the above it about your only options.
Kelly
Feb 25, 2010 | Karcher PSI Electric Pressure Washer
In my question as to using two inverters of 110 volts each, they are not to be run in series but parallel. One inverter would tie into one side of the electrical panel and the other would tie into the...
this solution would likely work fine if you were only looking to have 110vac power. In order to have 220vac from two 110vac devices, you would need expensive equipment, and technical knowledge.
What you need to do in order to get 220vac is buy an inverter that will provide 220vac. There are many available.
Hope that helps.... Good Luck!
Nov 23, 2009 | Electronics - Others
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
