SEASONAIR KFR- 26 W - Heating & Cooling
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
How can i find the electrical diagram of split condionner mdel kfr-33gw/j ?
There are service manuals here for the 33GW/C and /D. I have not been able to find one for the /K, sorry. Hope this helps anyway. Warning: The manuals are big and take a few minutes to download. They're also in Japanese but the pictures are good. Good luck!
HITACHI Air conditioner Manuals
May 20, 2014 | Ruud Central System Air Conditioner
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
KFR-12G New Compressor.....Draws too much amperage now. As though it is in the start mode all the time. New Capacitor too. Not overcharged either. Wiring is as it was originally. Thanks in advance.
Well, I looked at the date of post, doubt, you still need help, But, you can try a hard start kit. A generic one will do. It may decrease the life of compressor though
Oct 27, 2010 | Soleus KFR-12G Air Conditioner
Kfr 24w condensor will not run
Check the contactor to see if the contacts are stuck or welded together, if not check to see if you have 24 volts to the contactor, if you do then the thermostat is not opening.
May 17, 2009 | Comfort-Aire BHD-301 Dehumidifier
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Soleus KFR-18 Air Conditioner Problem
Check your thermostat settings at heat mode.
Jan 03, 2008 | Soleus KFR-18 Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
