Question about Dryers
Buttons on front of dryer are too hard to press. What is problem.? Fisher paykel auto sensor.
    Sergeant:
  • Dryers Expert
  • 448 Answers
Need new control
Posted on Dec 06, 2013
  • 1462 Answers
SOURCE: Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Posted on Nov 14, 2008
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
  • 172 Answers
SOURCE: Fisher & Paykel front loader dryer ED56AU
What about the lint sensore, it may be faulty, sending a signal of a fire hazard.
Posted on Aug 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
SOURCE: need a manual for fisher and paykel drier ED56
try here http://kitchen.manualsonline.com/ex/thread/view/idThread/2200997
cheers Sandy
Posted on Jul 02, 2010
Dryer moisture sensor not working
coolblueworld.com is fisher paykel wed sight
Mar 07, 2014 | Fisher and Paykel Dryers
Fisher Paykel front control board power on press key not accepting. As if it is stuck?
how old is the machine? all buttons are rated for a certain number of presses. they can be removed with a soldering iron and replaced with similar buttons if you are so inclined. or a new board can be purchased from F+P.
Oct 29, 2013 | Fisher and Paykel Washing Machines
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Diagnostic Mode
button.
Last Fault
The manual is here
Sep 08, 2009 | Dryers
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
button.
Last Fault
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel (NZ) tumbler dryer
Try switching off the power to the machine for 5-15 mins and then re-switch power on
Had same symptoms with my multi-temp F&P front load dryer.
Andy
Nov 30, 2007 | Fisher and Paykel DEGX1 Electric Dryer
It wont heat at all. lint trap empty, good air flow
needs a heater rework kit probably. contact fisher paykel and they will pay for the repair.
Nov 02, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
Top Dryers Experts
