Question about Vacuums
Vacuum cleaner vc h3301 wal mart
I need to replace the hose as it's torn where it fits onto the the part you hook to the sweeper...also need a filter
SOURCE: sanyo vacuum cleaner bag
We have the Sanyo Transfomax 3 in 1 vacuum and FINALLY found that one has to use a screwdriver at the edges of the "hand hold" just above the Sanyo name (between black and green parts), to pop open the cleaner in order to replace the bag or clean the filter.
What a miserable way to change a bag!
I know this is almost a year late...but I just found your request. Ta ta, Rita
Posted on Jun 13, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
SOURCE: Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Posted on Jun 24, 2009
How to fit hose?
Some vacuum cleaner hoses are glued onto the metal fittings. If you are replacing one, the old hose has to be cut to remove.
Apr 18, 2016 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Where can I get a fiter for my GE Combination Bagless Vac model 106687
Greetings,
Your GE is actually made by Eureka for Wal-Mart. Wal-Mart owns the GE brand for vacuum cleaners, and they have different manufacturers (most always Eureka) make vacuum cleaners specifically for Wal-Mart, but in actuality it's really a Eureka vacuum cleaner in terms of the parts (most of the time, in this case for sure).
Your GE model 106687 uses Eureka Dust Cup Filter Part Number 61518. Here's a link to Amazon for the filter;
http://www.amazon.com/Eureka-Model-106687-Filter-61518/dp/B001DPLYAG/ref=sr_1_1?ie=UTF8&m=A13YM4FUDXTJG6&s=generic&qid=1269298852&sr=1-1
The parts Diagram for your vacuum cleaner can be found here;
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/GE106687.pdf
This will give you all of the Eureka part numbers for your GE Stick Vac. I hope that this was helpful to you. If you found this helpful, please be sure to rate the answer as helpful by clicking the 4 thumbs up icons in the top right hand corner.
If you need any other parts, please feel free to contact us.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | GE Combination 106687 Upright Vacuum
Bag came apart from hose
do you have the instruction manuel? .if you can't figure it out i would take it to a repair shop and i'm sure they will be happy to show you how to do it.
Mar 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
I bought my Hoover...U5180-910...@ my local Wal-Mart. It is literally falling apart. The sweeper has NOT been abused. Yes, we have 2 cats & a dog but the problems I am having w/ it should not be...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=729453
Generic problem for all Vacuums
Posted by ldjezt on Jul 01, 2008
I bought my Hoover...U5180-910...@ my local Wal-Mart. It is literally falling apart. The sweeper has NOT been abused. Yes, we have 2 cats & a dog but the problems I am having w/ it should not be warranted. The handle has broken. The wheel/roller on the bottom of the machine has broken off & now it has just stopped working. I repeat, this vacuum has NOT been treated badly @ all. I can not be w/out a vacuum. Thank you for your help, hopefully. Debi
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do if the vacuum is less than a year old then take it to an authorized Hoover vacuum cleaner dealer and some parts and maybe not all might be warranted
The handle can be fixed and the wheel roller also can be fixed by any vacuum cleaner dealer. With pets the suggested belt change should be done every 3 to 4 months with 2 cats and a dog and the extra belts should be stored in a Ziploc bag in the refrigerator. If the vacuum just stopped working it could be the motor and if less than one year might be warranted. Feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Vacuums
BISSELL POWERFORCE BAGLESS UPRIGHT FOOT HOSE IS TORN
Take the top cover off, unscrew where the hose hooks onto the back, then you can get to it.
Nov 18, 2007 | Vacuums
Eureka Central Vac-Sweeper -Model B1501
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
