Question about Garden
Hoffco string trimmer manuals
String trimmer mnaual hoffco GT-14
  • 246 Answers
SOURCE: How do you change pull rope on Poulan pole trimmer
Hello theframptons:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
#1 Taper
  • 1041 Answers
SOURCE: only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Posted on Jun 17, 2009
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
canbruce75
  • 1776 Answers
SOURCE: how to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Posted on Aug 30, 2009
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
Posted on Jan 09, 2010
Having trouble replacing the string on my XP Electric. Not sure how to correctly wind the string.
On this page under "Downloads" click on Instruction Manual "Print Doc" and your owners manual will download. Inside will be detailed instructions with diagrams on how to do your procedure.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=GH1000&selectedType=16880#
May 15, 2011 | Black & Decker 14" Grass Hog Xp...
Changing the spool/ need to place more cutting thread on.
Unable to download your exact model (Mighty Lite) manual. Here are the instructions for stringing a different model with hopefully the same type string head. See pages 14 & 15 of this manual. You will need Adobe Reader installed on your computer to view this.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
Apr 09, 2011 | Homelite Mighty Lite Lawn Trimmer
How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
Jul 01, 2010 | Black & Decker 14" Grass Hog Xp...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
Only 1 string trimmer /// string keeps feeding when running
Jim
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
