Defy automaid da455 manual - Washing Machines
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
SOURCE: defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: My Defy Automaid 600 does not run water in. Tap is
HI. this is a failed inlet water valve assembly. you will need to replace this assembly asap if possible.
Posted on Jun 11, 2009
  • 17 Answers
SOURCE: How do remove the bearing behind the drum on Defy
Try Youtube below. This video really helped me when I replaced mine. Basically the entire machine has to come apart. If you are lucky, its just the bearings and seal. I replaced my bearings and seal for under $30. The bearings are likely Chinese in origin, mine were on my Kenmore, I replaced with more Chinese, you can buy SKF which are more money but likely wont last any longer, basically submerged in water a lot. The bearings will be able to be knocked out of the plastic drum with a little effort once you completely dismantle the plastic drum which has about 20 bolts or so. Now remember, the bearings only seat in one way, so dont beat on the bearings too much with a hammer and screw driver, they should come out without too much effort. They press in place, so save the old bearing and lay it on top of the new one to tap it in place. It depends on which model you have. It is likely a Frigidaire, look at the drum when it is exposed, it may be stamped. Anyway, it does not matter, if it is the bearings, they will need changing, and the rubber seal that goes over the shaft too. The seal may not look too worn, but it is, and the water has come in to where the bearings sit, so you can guess at what happens after awhile. Also, if you are not so lucky, the aluminun tribar housing holding the stainless drum onto the shaft will be cracked, if that is the case, you may want to look at another machine as parts may be too expensive. Just remember, the bearings will be standard type, and will be stamped into the race for identification. Google the bearings numbers and you will find them. Find a local supplier of bearings and they will find them for you, and the seal. It takes about 3 hours to dismantle, going slow, and a little less back together If you are a handy person, you can do it but on a scale of 1 to 10 it is about a 8 for difficulty. The hardest part for me was getting the darn aluminum belt pulley off the back of the drum shaft, what a nightmare, it was siezed, I had to use my propane torch being careful not to overheat the plastic drum.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=related
Posted on Sep 20, 2009
Testimonial: "Thanks, looks as though it wont be the train smash I originally thought it mite be"
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
Pre
Sep 05, 2014 | Washing Machines
My DEFY Automaid 600 does not heat the water
It is possible that the thermostat may be causing a problem if it is faulty. It might be sending wrong signal to controller confusing it to think water temperature is already reached and shut off the heater.
The thermostat may look like this part.
http://www.macspares.co.za/laundry/thermostat-defy-automaid-std-models?cPath=1_195_175&
Apr 25, 2014 | Washing Machines
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy automaid instruction manual how to use
Apr 03, 2009 | Washing Machines
Defy automaid won't spin
Good luck.
Mar 10, 2009 | Washing Machines
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
