Question about 3Com Baseline 2924SFP Plus 24Port Gigabit Ethernet Switch (3CBLSG24UK)
Zyxel es108a factory reset - 3Com Baseline 2924SFP Plus 24Port Gigabit Ethernet Switch (3CBLSG24UK)
Zyxel prestige 600
Try the default factory username and pw. User Name: admin Password: 1234
If this doesn't work, review the information from the linked users guide for resetting the device to factory defaults.
http://www.zyxel.com/support/Zyxel-password-changing-procedure-20161213-v2.pdf
Nov 29, 2017 | Computers & Internet
Hi, could any one help me reset zyxel prestige 100ih password?
There should either be a small button or a pin sized hold on the back labeled "Reset". Hold this in for about 10 seconds and the router will be reset back to factory settings.
Apr 02, 2012 | Zyxel Prestige 100IH Router
Ihad telefonica zyxel p660hw d1 router ,iwant to attach it to my computer so i want its configuration idont have its user name nor password ,help me.
To reset to factory defaults
1) Power off the router,
2) Hold down the recessed reset button on the rear of the unit (keep it held down)3) Power on the router with the reset button still pressed down.4) You will notice all the LAN lights flash at the same time which will indicate that the router has reset - this takes up to 30 seconds.5) When all the LAN lights do flash simultaneously you can let go of the reset button. Your router is now reset.  The default IP address is "192.168.1.1" and the default password is "1234".Also consult:  http://www.zyxel.co.uk/web/support_faq_detail.php?faqID=17&pid=20060330164958
Apr 21, 2011 | Zyxel P660HW-D1 Router
Hor to reset my router zyxel 660HW
There is a small button/hole at the back of the router. Usually you need a pin or an sharp object to poke the button.
Press & hold the button for 5seconds to reset your router to the factory settings.
Apr 05, 2011 | Zyxel Prestige 660HW Wireless Router...
I HAVE FORGOT MY PASSWORD ROUTER ZYXEL P660HW-61
Hold down the reset button on the router for 30 seconds and that should reset it all to factory setting including the password, which should be on the bottom of your router
Mar 26, 2011 | Zyxel (91-004-361002) Wireless Router
I am forgot zyxel switch password and ip adress then how can do factory default setting.
look for a small pinhole that is reset switch power up insert paper clip 5 seconds should reset all passwords
Jan 27, 2011 | Zyxel ES-2108 8PORT 10/100BT MAN L2 SWITCH...
How to reset e zyair g-1000
On the Zyxel ZYAIR G-1000, the reset button is the small hole between the LAN socket and the power plug socket. Simply press this button for 10 seconds, until the link LED turns red. This will reset the unit to factory default settings.
Dec 01, 2010 | Zyxel ZYAIR G-1000 (91-005-026001)...
I wish to restore the factory settings for my Zyxel router
You may call on 1-800-585-2494 toll free for support on zyxel support.
Dec 31, 2008 | Zyxel Prestige 334 Router
3Com Baseline 2924SFP Plus 24Port Gigabit Ethernet Switch (3CBLSG24UK) Logo
53 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
