Question about Kenmore Magic Blue 24195 Bagged Canister Vacuum
How do i change the bag? - Kenmore Magic Blue 24195 Bagged Canister Vacuum
Changing bag
The cloth bag can be soaked in warm water with a mild soap solution. Rinse well and let it hang to air dry. We usually let it hang all day in the sun when we can.
Mar 23, 2014 | Oreck XL2200 Bagged Upright Vacuum
How to change bag
Hey, changing the dust bag can be a little difficult. Remove the old dust bag, then using a new dust bag, align the cardboard wiht the bag holder's black grooves. Slide the bag cust into the grooves with the black arrow pointing up.
Here's a link to the user guide if you can't locate yours.
http://www.bissell.com/user-guides/?searchtext=4122&searchType=search&mode=undefined&lf=228&cid=ccsocial
Dec 25, 2012 | Bissell Vacuums
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum will not stay on, new bag in place and power to machine.
It sounds like you have a bad control valve. Take it to you nearest Aerus (formerly Electrolux) dealer and have them change it for you. It shouldn't be too expensive. Good Luck!!
Jan 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Kenmore Magic Blue 24195 Bagged Canister Vacuum Logo
66 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
