Dvd burner 1 to 5
When turning on the burner it beeps showing failo with numbers. It will not go to copy screen instead it goes to advance set up number 12
IFIXALL
  • 868 Answers
SOURCE: Serial Number:
Ok remove the burners first,then with a thin 25b4c19.jpgscrewdriver or even a butter knife push it between the front cabinet and the top to release the clips (2) that are holding this top down.see pix.
Posted on Jun 11, 2008
iservice
  • 318 Answers
SOURCE: 4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Posted on Nov 03, 2008
SOURCE: remote not beeping or lighting stove
go to pro com. com
Posted on Dec 31, 2009
budmrtn
  • 11361 Answers
SOURCE: VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 07, 2010
bronk50
  • 27725 Answers
SOURCE: I have a lg cd/dvd
if its a cd/dvd burner it will depend on which burning sofware you are using some will support burning media files and dvd's some will not you could search the internet for some free ones if you do not have any of this software cnetdownload.com also majorgeeks have lots of this free software
i will attach some links you could try if they dont suit your needs just uninstall them
http://www.nero.com/eng/downloads-nbl-free.php
http://www.majorgeeks.com/BurnAware_Free_d5839.html
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://www.majorgeeks.com/ImgBurn_d4870.html
http://www.majorgeeks.com/ShrinkTo5_d4755.html a dvd copying program
http://download.cnet.com/free-easy-cd-dvd/3000-2646_4-10627009.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps
Posted on Apr 17, 2011
HOW DO I RESET MY1:11 TECH-COM DUPLICATOR?
how to reset 1-11 dvd techcom controller.
-when it is on aqnd the screen shows copy use the top arrow key to move to setup when in setup look for reset
May 06, 2011 | Primera Technology Bravo II DVD Duplicator...
When I press print, it defaults to the mp tray feed. It shows in the screen that the default is the tray 1, but it goes to the the MP tray instead.. how do i fix this?
While I'm not familiar with the T632, I have a C782 with the same problem. I, too, tried changing the Paper Source settings with no help. Instead, I went to "Settings" then "Copy Settings" and then changed "Copy to Source" option to the value of "AutoSize Match". This fixed both our copy and print problem. If your printer does not double as a copier and does not have this option then I don't know what to do.
Feb 19, 2010 | Lexmark T632 Laser Printer
Gateway laptop with DL/dvd burner, burning problem, it stops at 5% and ends with burn fail. i tried all writing softwares under winxp , win 7.
What are you trying to copy? Data? Music? Movie clips? The only thing I can think of is to make sure that what you're trying to copy isn't bigger than what the DVD can hold. That will definitely cause the problem you are describing.
If that's not the case, make sure you do in fact have a DVD in there instead of a CD. Also, make sure your program is set up to copy to DVD instead of CD. You might have hit an arrow and inadvertently set it to CD.
You might also want to try reading a DVD. Do you have any problems reading one?
Make sure also that there are no fingerprints on the disk you're copying to, and try it with three or four different disks.
Or try disconnecting your modem, then turning off your virus checker, and copying it again to see if the virus program is blocking something.
Sep 25, 2009 | Computers & Internet
My drive will regognize and burn cds but when i try to watch or burn a dvd it says unkown or invalid its an hp dvd writer 420n
install the corect hp drivers and check the windows settings to make sure it is not sean as a cd drive instead of a dvd
Aug 03, 2009 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
Laptop beeps but will not turn on. screen stays
Symptom sounds like a memory module came loose, worse there may be a crack on *********** board. Re seat RAM, or take it in to be serviced. Dead or low CMOS battery may also exhibit this symptom.
Jul 29, 2009 | Compaq 430186-001 - HP Pavilion dv8000...
Pead only cannot write or copy
sorry frn, your write lens of DVD is full of dust or it may be damage, so use Lens clener to clean the lens. and try to copy the cd. ok byee
Apr 13, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
Dvd burner not detected by adobe premier pro 2.0
Hi there thanks for your post
You need to go to advanced settings and in the settins tab there should be setting that appears as current drive is should be selected blank from wat you have told me click your dvd bunre that should fix your problem
thanks and please rate me
Jan 18, 2008 | Computers & Internet
T23 notebook
Yes no problem.
Sure they made DVD writers for those - usually about $80-100.
If you just want a CD burner and DVD player they are only $40-$60.
You can easily eject the drive by hitting the release lever to the right of the CD drive.
The CDRW/DVD combo part numbers are 08K9820 22P6980 08K9818 or 13N6765
They have cdrw/dvd combos for $34 at compuvest.com brand new. I saw DVDrw drives for $70 on ebay -look for part numbers 08k9868, 08K9694, 08K9572, 08K9818, 08K9820, 08K9867, 22P9109, 22P7011, 22P6991, 08k9785, 27L4358, 08k9784, 27L4359
Dec 21, 2007 | IBM ThinkPad T21 Notebook
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
