Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Red light flashing
Red Flashing light on temperature control panel & continious beeping can you help please
4 Suggested Answers
  • 3 Answers
SOURCE: Active Smart Temperature Control Panel - Red Light
it is possible that it is the cooling regulator that is having a fault. The F&P customer service centre will / should be able to help diagnose this over the phone and give you a much better idea what u should do.
Posted on Jan 08, 2008
espressonist
  • 1711 Answers
SOURCE: Identify (an remedy) fault. Alarm sounding and
Fault Alarms
If the electronic controller detects a fault from which it is unable to recover an alarm will sound.
When the fresh food compartment door is opened a fault code (specific pattern of lights) will
flash red and green on the Control panel to alert you to the fault. The audible alarm will stop
when any button is pressed but the lights will remain flashing.
If such a fault occurs, call your Fisher & Paykel Appliances Authorised Service Center immediately;
the fault code will help the service person find and remedy the cause of failure.
Posted on Sep 26, 2010
  • 867 Answers
SOURCE: Our upside down fridge/freezer started to beep. Upon opening the fridge the thermostat lights on the back was flashing red then green then red again anyone help?
This is a connection issue between one of the temperature sensors and the electronics, the plugs on the sensors need to be removed and cleaned with contact cleaner and you need to make sure that the contact are pushing firmly against the circuit boards, there are 2 control units, one behind the fridge beside the compressor and one in the back of the fridge which you get to by simply pulling the middle rear panel out after removing the shelves, just be careful as you can damage the plastic.
Posted on Mar 05, 2012
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Three lights flashing on the control panel
check recirculation pump heater element and pressure switch
Dec 29, 2012 | Heritage Pool & Spa
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Mar 05, 2012 | Fisher and Paykel Active Smart E522B...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
151 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
