Question about Shark Navigator Light Weight Upright Bagless Vacuum Uv300 26 Pet Hair Canister
The light for the brush roll will come on only if I hold it down-when I try to vacuum it goes off
  • Shark Master
  • 18,424 Answers
This link is the manual go to page 6 it tells you there are two buttons one for power one for brushroll...
http://www.sharkclean.com/manual/UV300_26_IB_ENG_SPA_110831_5.pdf
Posted on Nov 29, 2013
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My shark vacuum nv350w26 carpet brush has quit spinning. The green light comes on and the brush goes for about 5-10 seconds and then the light changes to red and the brush stops. Any ideas??
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=nv350
Ava B.
Dec 04, 2016 | Shark Vacuums
Why wont my brush rotate no visible blockage
Start be replacing the belt and making sure the brush roll turns freely.
Apr 01, 2015 | Vacuums
How do I change a belt in a Riccar vacuum
Remove the screws holding the bottom plate on. Remove bottom plate. If it's an 8955 or model with clutch to shut off the brush roll remove the rod that goes from the lever to the clutch. Look closely how the rod and brush roll are positioned in the vacuum so you can reinstall it the same way. Remove the brush roll and install the new belt and then put back together as it was.
Apr 30, 2014 | Riccar 8955 Upright Vacuum
Change brush indicator light
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Mar 30, 2014 | Kirby G4 Bagged Upright Vacuum
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
How do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Apr 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Red Devil vacuum
Turn the vac over, remove the screws holding the plate covering the brush roll and belt. Belt goes from the brush roll to the motor shaft or pulley.
Dec 22, 2007 | Royal 5300 Upright Vacuum
Shark Navigator Light Weight Upright Bagless Vacuum Uv300 26 Pet Hair Canister Logo
128 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
